drewpy
Everything posted by drewpy
  1. there should be a live connection to the coil from the cdi. so you need to find that. Don't fire without a spark plug fitted as yam says it damages the cdi box.
  2. drewpy replied to dt250Man's topic in Classics
    you also use the vacuum on the the manifolds to hook up the vacuum gauges
  3. just connect and see, it won't do any harm as the sparks will still happen just at the wrong time. I do it all the time and never bother writing down which is which.
  4. drewpy replied to dt250Man's topic in Classics
    the pet cocks are easy enough to repair as you get all the gaskets etc and you keep the originality of the bike if its well looked after! I would def need mine as I forget to take my keys out of the ignition never mind switching off the petrol!!
  5. drewpy replied to dt250Man's topic in Classics
    glad you got that sorted. brit xs's don't have relays for lamps!!
  6. its just rubber holding them in, so gentle tweeks are in order and they should pop out!
  7. nice view of an XS400 cup near the end this bike is freekin LOUD ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525">
  8. drewpy replied to jamax's topic in Yamabyss
    fox on the run, you scream and every body comes, a running.....classic
  9. exactly the same engine except for bore, valves and carbs btw please start a new thread as its
  10. the seat is off the shelf an XR750 replica I belive try hot wing glass or omars for these sort of things
  11. that bike is amazing, god find djcrow
  12. impact driver with a tight fitting allen key or basj on an over size star/torx key
  13. hey, they're called ice cream legs, coz girls want to lick them when they're HOT!! its stock wiring which i am taking out all the unessary bits coz I'm running with ignition, brake light and horn and that's it. minimum for the MOT
  14. at the top of the fork slider there should be a collar which unscrews. you can see it better here
  15. there was two different types of dohc xs400, 36hp and 45 hp you may have the 36hp one.
  16. i'd check the worm gear on the clutch cover is not broken. its only plastic and I'm not sure how you can break a 200lb breaking strain cable unless its rotten!!
  17. unfortunatly i am going away weekend with the family. Did you get rock radio to advertise it, i think it is free if you go on the website!!
  18. dem links don't work for me!!
  19. not really, could'nt hear them anyway
  20. drewpy replied to romjag's topic in Classics
    what says AT1 - 171537, the chassis number?
  21. started off as kenny roberts modified xs650, then the idea grew from what was around. I get sideburn magazine which captures the spirit of the bikes, and also this..... on the mile long tracks they are on 120mph and 8o round the bends.
  22. I've got the maxxis 3:50 on front and 4.00 on rear. for the flat track look I don't think I could go bigger on the rear check out the end my flat tracker thread in the street bike section for the tyres. bear in mind the bike is slightly raised by 2"
  23. drewpy replied to drewpy's topic in The Bar
    Wow that's some writing Bark!! love the choice of music
  24. ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"> thought I'd start it up as I have just upped the mains to 135 from the DOHC'c 125/127.5 runs a lot better now as you can hear, but its bloody loud and next door came out saying "Oh you got another bike?" hmm nice quiet engine as well (compared to the exhaust )
  25. drewpy replied to barkwindjammer's topic in General
    oh so disco very is discovery, yep i saw it. just couldn't understand what you were saying
