Everything posted by drewpy
400 frame same as 650?
no where near, 650 engine is taller.
REMEMBER
- XS400 speedo lights burnt out, apparently
or DAZ or OMO or Persil- Xs400 Wont start up
yep, battery and flooding, that'll mess it up and even if the battery has 12v, the amps may be gone. happened to mine in the pissing rain, it started missing and wouldn't run over 50 mph. new battery and voila!!- what a fruit cake
- carb problem
you'll need a good amp charge to turn over the bike and run the CDI. get your battery amps checked or buy a new one as I think yours is on its way out!!- XS 250
you don't need Lead Replacement Petrol, all jap bikes from the 70's were designed to run on unleaded. As OG said check filter and vacuum petrol tap. you would be well to strip those carbs and give the bike a good service. Also coils can break down after a bit due to their age.- damned reinforced concrete
re-enforced concete is very strong- New carbs for XS 250
so long as you ask them to supply the jets for a 250, can't see why not- FS1-E Restore
will this one do? here try yambits site as well- Resurrecting a 78 xs 400 thats been sitting for five years
why? coz you always leave late, as you come too quick- damned reinforced concrete
it tumbled like a matchbox? never seen matchboxes tumbling so i couldn't comment- Yamaha XJR
- local shows lancashire
voodvale rally is on only stunt bikes but loads of petrol head stuff like this- Pepair of sidecovers
good tip. some people melts tie wraps into the crack to weld a repair- 81' Yamaha xs 400 electrical problems/fuse box
ebay uk has remanufactured fuse boxes for sale. you just need to get another connector to rewire the bike. ebay- XS250SE
did you mix up the coil connections with the points. try switching them round. don't forget LT/RT is TDC for valves and LF/RF is for checking timing (contacts begin to open)- carb problem
maybe the battery is on its way out and the starter sups all the available juice so the ignition gets starved. its just you said that it starts ok on bump- Is there a dip stick on xvs 125 dragstar
damn you beat me to it!!- 1977 Yamaha XS500D
coil heating up and going bad?- Resurrecting a 78 xs 400 thats been sitting for five years
glad your making progress. I think its a matter of ensuring you can brake ( new fluid every 2 years!!) and that the engine has good oil and is tuned up. start collecting tools as you can afford them ( even second hand) strobes are good for timing and vaccum gauges for occassional carb balancing ( go halves with someone) drewps- Can I Repack the Exhaust on my '78 xs 400
I would say that's an after market exhaust as original yams were welded. I would go ahead and do it but don't over do it as you'll strangle the performance- yamaha xs400 fzr rearsets?
not sure, if its cheap enough try it as Rassk rear sets cost loads- Gear lever axel on 500 XS broken
if its like the xs400, you need to drain the oil out and take off the right cover. than dismantle the gear selector parts and slide out the shaft. I bought a new one from yambits as its the same as an RD400 D/C- FS1-E Restore
I would have though this site to be your best bet http://www.fs1e.co.uk/ - XS400 speedo lights burnt out, apparently
