drewpy
Everything posted by drewpy
  1. not as bad as OG's toe incident
  2. never had any probs with mine except for wear on the spindle. a lot of riders jab at the kickstart which will put an undue strain asthe slack gets taken up. I'm sure if its done properly there would be no issues. maybe a previous owner misused it? not sure about the hvc stuff, but very expensive!!
  3. I've read this 5 times and I can't quite get what you are saying!!
  4. Absolutely terrifying NZ road safety notice that oozes blood whenever it rains. ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="873" height="525">
  5. if the floats drop into the bowl and are not fouled in any way, the ideal height will be 3mm from top of gasket when full of fuel. i think you need to experiment with the float heights. So to answer your other question, no, the floats would not just drop in without some sort of tang bending. I hope the floats you got are able to do that as some floats are fixed for a particular carb!! 34mm is the venturi nearest the engine.
  6. bravo Fabiamo. benvenuto e YOC drewps
  7. drewpy replied to hovercad's topic in General
    hovercad
  8. buon compleanno, there's life Jim, but not as we know it!!
  9. i use firefox, a sticky is a pinned thread that stays permenantly (until the mods see fit) at the top of the catagory.
  10. did you just check for volts or amps (hard without the right equipment)
  11. drewpy replied to lison766's topic in Classics
    matt/satin black dissapates heat efficiently, go ask the aircooled rd boys in their forum!
  12. Foamy take note of this.... came via chopper underground
  13. drewpy replied to lison766's topic in Classics
    someone should tell Yamaha then, they must have it all wrong
  14. nice bike! this guy fitted xj550 forks for dual disk conversion check out the sticky section for xs400 info ( in classics )
  15. there is 1 here Part Number 1A8-13596-00-00 DescriptionJOINT,CARBURETOR 2 XS500 76-77 RH Model XS500 C 1A8 Price $98.45
  16. excellent wite up and pretty much spot on with my ownership of this bike, although mine pulls up to red line ( well it did when i was racing an rd at wombwell). you can replaces the plastic swing arm bushes (original yam) with bronze type which last a lot longer. to the forum manic drewps
  17. drewpy replied to ardo's topic in General
    loads on ebay drewps
  18. "Yurt" having a laugh arn't you? I build me own shelters if I'm doing survival camps. they work really well when its dry
  19. drewpy replied to Joshua2's topic in General
    the gp boys clutcless up shift but have ignition control which cut the engine as the gear lever goes up. that way they hold the throttle open all the way up the gears. they use clutch on down shift, but with slipper clutches so the back wheel don't lock up!! I'vre done it, but nothing to gain and I may break a 30 yr old bike!!
  20. drewpy posted a topic in Video Section
    ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525">
  21. they are not fixed just mechanically hidden
  22. also check you are charging. 14.5 volts @ 3k revs ( when it starts) try disconnecting the head lamp and see if it works ok again!!
  23. where they ultrasonically cleaned? its amazing what comes out of "cleaned" carbs, we had a thread last year where the guy swore blind his carbs were clean ( till he saw the light)
  24. sounds like its running a little weak, adjust your pilot settings front of carbs. until you get the floats sorted, you can't expect too much in the way of performance!! I do like the quiet surburban backdrop, then start revving the bike up and the dog starts barking etc
