Everything posted by drewpy
- newbie
a quick hello
baz. enjoy your R6 ( but don't go too daft)
- Introducing myself
1993 SR125 query
if its a spoked wheel, you can get a new rim laced onto the hub. try central wheel, brum or wyldes in leeds
CDI/ECU Problem
a newb sent a report message to the mods, so here is nickson's message 1w 681 j resistor mark make of it what you will
light white smoke
from the exhaust it could be flooding of the carb. mine did/still does that,(another job on the to do list) burnt oil is blue in colour. there realy should be a seal around the header as no smoke should be comming out there, so i would get new gaskets.
Xs400 Wont start up
I wonder if the headlamp relay is faulty and causing a drain on the electrics?
Painting an Engine
don't forget to cure it in the oven, otherwise it won;t be petrol proof and can chip easy!!
Question reguarding brakes
have you felt the weight of the xs alloy wheels? they weigh a ton. i spent lots of money converting to spokes (although I do have disk brakes) drewps
- rd350lc
- Hi Everyone
What the heck is this??
i thought creamy goo is what mothers find in teenager's beds!!!
1981 XS 400 Special II
the "hanging" of revs is down to gummed fuel in the pilot system, you may be able to tweek the pilot screw richer.
help mounting new brake rotor
use thread lock, normally the bolts already have the thread lock on then like this
Manchester Riders
just comming back from Austria with the scouts, so I might have to give it a miss.
3 new bikes in the stable
cool, keep us posted in the classic section drewps
Allow me to introduce myself!!
to the YOC steve-0
- Hello ALL
Where can i get a bike from
bike shop!!
How Strange The Change From Brass Floats to Plastic
get your carb kits from siriusonic
Timing Chain Question:
or float height has changed. try running some fuel cleaning additive through the tank to see if it helps
You all helped, XS 400 RR (2nd "R" means it runs)
coming along nicely
Broke my kickstarter yesterday.
what i meant was take up the slack and feel a little resistance, then swing. some folk just put a foot on the kick and wack it through putting undue strain on the system. the cg125 i got had a snapped kicker.
Widow- Maker
bet that'll cost you an arm and a leg.......leathers, helmet etc
- New Guy
