drewpy
Everything posted by drewpy
  1. drewpy replied to ardakota's topic in Classics
    charge battery, it needs a GOOD 12v
  2. drewpy replied to bznchris's topic in Yamaha Gallery
    I was was quite normal looking then, as am in catering. the long hair was the 70's, yea baby!!
  3. where did that golf ball go? <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  4. drewpy posted a topic in Video Section
    This is the world’s largest single-cylinder two-wheeler. It was built by a gentleman called Fritz Langer, and it’s based on an NSU Konsul 500. Fritz replaced the original cylinder and piston with a 122 ci unit from a radial aeroplane engine, but that piston weighed 3.3 kg—over 7 lbs. So Fritz got Mahle to make up a lightweight piston of just 1.6 kg. After the engine block was widened and the crank milled, Fritz was ready to roll. The stainless steel exhaust system, incidentally, is 75 mm (3 inches) in diameter, and there’s no silencer. So it’ll be enough to put even a Screamin’ Eagle-equipped Harley to shame <div style="width: 400px;"><object type="application/x-shockwave-flash" data="http://www.gaskrank.tv/tv/intradat/etc/player/gaskrank.swf?image=http://www.gaskrank.tv/tv/intradat/branding/playbg.php&logo=http://www.gaskrank.tv/tv/intradat/etc/player/t1.png" width="400" height="320" wmode="transparent" flashvars="file=http://files.evisor.tv/200708/1451.flv"> <param name="movie" value="http://www.gaskrank.tv/tv/intradat/etc/player/gaskrank.swf" /> <param name="wmode" value="transparent" /> <param name="flashvars" value="file=http://files.evisor.tv/200708/1451.flv&image=http://www.gaskrank.tv/tv/intradat/branding/playbg.php&logo=http://www.gaskrank.tv/tv/intradat/etc/player/t1.png" /> </object> <div style="text-align: center; font-size: 10px;"><a href="http://www.gaskrank.tv/tv/motorrad-oldtimer/bison-lebt-teil-2-1451.htm" target="_blank">Bison lebt - Teil 2, NSU Bison 2000</a> <br>powered by Gaskrank.TV</div> </div>
  5. nice one, made me chuckle ...like a chuckle brother
  6. drewpy replied to bznchris's topic in Yamaha Gallery
    had a sticky steam valve, finally freed it with a monkey wrench
  7. drewpy posted a topic in Video Section
    This is brilliant, if you can understand it <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  8. drewpy replied to bznchris's topic in Yamaha Gallery
    I'm having my tank made as we speak, should be ready in a week or so!
  9. it says so on the battery description. her's one http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350256044243 or use a .8amp like these guys
  10. the xs special/heritage frame are a lot different than the standared frames as the seats are stepped. it would have been easier to put an xs400 engine in the 360 frame as the mounts are identical!
  11. bloody 'ell mate, you ok? more important is the bike ok? Got St George's day parade with the scouts on sunday!!
  12. drewpy replied to up.yours's topic in Classics
    that was a spec-tacular fail then
  13. drewpy replied to ivan's topic in The Bar
    velcome Ivan the terrible to the YOC whereabouts do you habitate?
  14. funnily enough based in Canada
  15. get 'em made in stainless. my mate had some for his 400 made for £60 pair. bargain I'd say
  16. its Chico time!!
  17. only avaialble 4th july as on Monton festival on the 3rd 25th i'm free as well ( its a better show)
  18. nice one
  19. Never mind OG .here's your most recent picture??
  20. that'll teach you to put a false birthdate down Paul all the best mate
  21. 1st when replacing with the taper bearings, i had to use a dremmel to cut the lower race out of the fork stem ( not all the way but enough to chisel off the part) get rid of the lower seal as well. the outer cups are the same, but the inner ones are diferent (I'm trying to remember now!!) drive the bearing in with a poly drain pipe, they can be cut shorter and are sacrificial ( i think they are 2 1/4 ") use plenty of grease and don't tighten down too much as you'll over load them just enough to take out any slack!! 2nd fork oil seals - are a pain to replace and you need to strip down the stantions via a allen bolt under the lower fork. if you can do this before taking off the springs and you can then quicky "snap" off the bolt before the whole stantion gets to move around with it. otherwise you need to make a tool to hold the innards to undo the bolt! ( do-able though) you use gentle heat to get off the seals and use a pry bar and soft cloth protecting the soft alloy ( this is after the stantions are taken off). if it still won't budge, self tapper screw into the seal and pull the F*ker out! for gaiters, you need to measure the top of the lower fork mount and stantion ( which is 33mm) and ask the vendors. drewps
  22. drewpy replied to BRIANM's topic in Yamaha Workshop
    erm, wasn't a right hand mirror was it? I think its a left handed thread your day just gets better and better
  23. drewpy replied to Andy1976's topic in The Bar
    hello Andy from West Yorkshire!
  24. and you are?
