Everything posted by drewpy
Front and rear fenders for XS400
to the forum Ben if you are in the UK, try custom fasteners have a look at my build on my tracker
- Module 2
i rode my XS400
aye, but when they run they're great. have fun pepps
8 month old baby having his Cochlear hearing implant switched on
that was fantastic, brought a tear to me eye
Mixture screws (XS 400)
happened to mine, twice!! grind a nail down real fine then tap them through the top with a pin hammer. this will push them through the hole, the hole will be bigger, but my carbs still run ok! drewps
82 XS400SJ Charging system nightmare
that sounds right
help please!!
motoward granby's yamahatopdog cmnsl bike bandit
just seen goff on the telly
Just this min seen the local news and a certain ms Goff (aka Lisa Bucley)was on there, summat to do with salford uni and a prosthetic leg for a foreign chap. if i find more i'll post found some http://menmedia.co.uk/news/s/1241008_student_brings_teen_10000_miles_for_new_leg
I'm back
I thought that all the xs range used allen heads!! anyways I always use an impact driver when undoing ANY cheese head screws
Hairy lipped squid, what are they like
oi loikes
- test
XS engine swap
I just notified them of the new CC and the engine number. did it when on SORN. its the frame that carries the reg number and that's the important one drewps
81 xs400 starter
how can the starter motor be filled with oil?, there is a water drain hole on the bottom left side, but i can't see any other way for oil to get in there! If your on the side stand and remove the 4 allen bolt stator cover, oil does come out. the bike needs to be on its main stand to remove the cover and left case. oil pools there via the crank bearing don't forget the starter clutch, which wears flats. you can get new kits from mikes SX
Engaged!!!!
way hay!! congrats to you both hope Claire likes bikes as much as you?
82 XS400R Seca headlight cut out problem
apply voltage and you should hear a click as the bus bar go across the terminals inside the unit. try and get a code off it as relays are really common and cheap.
14v @ 3k revs is within spec. with these bikes, you need a good battery, if it's not holding charge then you wan't get back a decent charge!! the tesing of the solid state voltage regulators only states the above test (14v - 14.7v) with a fully charged battery. rectifiers are diodes which only allow electricity to flow in one direction. this process converts AC current to DC, that is why you won't get a reading one way. I'd check battery condition firstly NEVER RUN ENGINE WITH BATTERY DISCONNECTED! drewps BTW I just posted a link for a parts book for the SJ under xs400 links
hardtails for a 1980 xs400
only company i know of PSW customs
Now and electrical issue.
when you get the bike going, run a volt meter on the Batt terminals. you should be getting 13 - 14.5 volts at 3k revs. if not i suspect the voltage regulator first drewps
Rattle
There seems to be a problem with these. this dragstar has a couple of rattles on the front end
Afternoon Everyone :-)
to the forum loopy i was busy with me tracker and polishing me other bike for tomoz ride
denis hopper
- Nudey CSS cleverness
Clever bit of coding - it's all perfectly safe for work, until you select all of the text and colour is automatically applied to each letter. http://fichtre.net/yop.html- 1980 xs 400 engine issues.
I'd tend to lean towards clutch drag. make sure its adjusted at the engine side first. there is another thread about this which, quite frankly, has been done to death- Just purchased a 1980 XS 400 special
got them from HEL- Bike "trading cards"
that GL750 was a rare one, built to offset kwacker KH and the suzie GT triples! thanks for posting - Nudey CSS cleverness
