drewpy
Everything posted by drewpy
  1. aircooled RD400 D is the same part, try HVC cycle in usa (assuming its a SOHC model)
  2. yep, you read it an XS400 on ebay for £3300 check it out
  3. drewpy replied to Airhead's topic in Classics
    looki'n good OG that reg plate must cost you a packet
  4. come on peeps only £19 left to target Shelter-me.
  5. drewpy replied to d.b.'s topic in Classics
    DB nice intro and keep the patina
  6. TM I think maybe your valves are stuck open for some reason, do you regulary ride the bike or has it been stored? try checking the valve gaps to confirm. other than that loose sparkplugs? drewps
  7. Got me ticket today for Wombwell near Barnsley today. If anyone is interested here's the link
  8. if you scerw in too far you will seat the tips and they will grip the sides and snap off. aircooled engines are noisy beasts, oil level ok? check valve clearances (tappets are for OHV engines ) cam chain can slacken and you can get piston slap if bore is worn, but it don't sound like that. you can get a long screw driver and hold the handle to your ear and touch the other end against the engine, this cam pin point any dodgy noises. drewps
  9. Buon Compleanno BWJ
  10. drewpy replied to friedegg's topic in The Bar
    my bike switches them off automatically (and its 32 years old) why not put in line a buzzer, won't forget then!! don't get too down, go for it again!!
  11. drewpy replied to happysnapper's topic in Yamabyss
    no sorry , take them through the small claims court, it does work although its a slow process as I've used this myself.
  12. if its the oldest biker, OG or OT will break the record
  13. he he
  14. went to VJMC lymm show today and met up with OT. good weather and as a brucie bonus got 3rd best Yamaha award. got a bit wet on the last mile to home, so i didn't timed it quite right saw a silver Saxon bike, this Silver Saxon turbo was manufactured by the top 70's tuning company S+S Performance, and is a prototype/development bike they used to try and crack 200mph back in 1977. The bike was sold to the heavy metal rock band Saxon, who used it as a stage prop in the early 80's. The bike delivers anything between 215 and 300bhp http://authortech.net/bikesite/Pages/Wil%20pages/saxon1.html for more info
  15. whats a needle valve seat clamp?
  16. drewpy replied to NHTodd's topic in The Bar
    to the YOC todd
  17. Xen I'd check the timing, especially if you have contact ignition (also check the contacts for pitting) you really need a xenon strobe lamp so it can be done when running. swapping over the coils also swapped the timming if you didn't swap over the feed wires. that will mean they will fire with the pistons at BDC. also sounds initailly like you have carb issues as, if you cleaned them properly, you would'nt get any crud in the mains. do you have an inline filter between tank and carbs? its poss that the tank is rusty inside, this will also affect the petcock. drewps
  18. no, we have both shift 3 and shift 4
  19. drewpy replied to Ladyboy Rider's topic in The Bar
    to the YOC Rick
  20. this guy just appears out of no-where, he's following you.... <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  21. I got a set from Mikes xs $10 a pop http://www.mikesxs.net/products-37.html#products I just guessed what i wanted and came out great especially as I had to have them imported
  22. I have to work that day now as my unit is having a make-over
  23. <object width="640" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
