drewpy
Everything posted by drewpy
  1. MMM, last time I rebuilt the petcock it leaked. Can't remember what I did to fix it though, I got an old one in me bitz box somewhere, give me till tomorrow and i'll dismantle it and check for you Drewps
  2. drewpy replied to MattR's topic in The Bar
    to the YOC don't forget to close those cemetary gates when you leave
  3. I'd say, carbs, exhaust, prop shaft lines/cables etc lie the bike on the side (everythng else is taken off) and lift the frame off the bike! why not send it for pwder coating. triple-s in bingley is not too far and don't charge much. they blast it and cover all the threads. here
  4. still sunday Isn't it John?
  5. fully charged battery. that's all I can think of except switch on the ignition
  6. xs400 will fit in with no mods
  7. I'd check the the ignition timming starting with the points gap using dwell if you have one. then strobe the bike drewps
  8. is OG on the run again?
  9. A-OOP david good intro! I like the triples especially the grey ones. electrics are the bugbear of the triples. Lots of the xs and rd range parts bins will cross over, just need to do a visual check. I have xs1100 brakes on mine, sounds good, but they are exactly the same as a 400 just the extra disk fitted and larger bore Master cylinder. SR calipers are the same and live on the left hand side while xs400/250 are on the right ( inc carrier) drewps
  10. can't you stick a stick oop the hole protruding into the tank?
  11. drewpy replied to oldtimer's topic in Yamabyss
    I can just picture you now OT...... with your 1 candle power torch
  12. wrap the tank in rags and wedge it in a cement mixer!! that'll get the stuff all over for minimum effort
  13. to me (i've had a few pints at this point) red, blue and brown are connected when the switch is in the "on" mode in park "P" mode, Red and blue are connected which enables the lights to work independantly of ignition. my igntion switch had a fourth wire to the main beam switch, which i soldered in
  14. drewpy replied to 2 Wheels's topic in Video Section
    you forgot this one
  15. drewpy replied to liam45's topic in The Bar
    liam
  16. i kick the bike on no stands, astride the beast!
  17. drewpy replied to 2 Wheels's topic in The Bar
    that was wank
  18. buon compleanno Boss! nice pressie England winning today!!
  19. you could turn the socket and screwdriver so it all come out and then see if the nut is damaged
  20. drewpy replied to cristi's topic in The Bar
    cristian if you want to post a want, please use the wanted section thankyou very much for your interest in the YOC
  21. if its blue i think it will be headlamp. get a online manual located in the xs400 sticky in the classic section (pioneerx links works)
  22. looks sic I'd change the pipes to straight thru with internal baffles and I like wraps on the downpipes
