Everything posted by drewpy
New Guy with Questions
check ebay for master cylinder rebuild kits. firstly, I'd strip the old one down to check the bore for corrosion btw to the YOC
Horses arses
good job they weren't measuring your arse then, could drive a hummer for that one
1976 XS360 replacement key...
blanks come up on ebay occasionally. tried yamaha?
XS400 Carb Compatability
all xs400's use a mikuni bs34 carbs, but there are differencs due to emmisions legislation over time. you can get a set of carbs from another 400 to fit yours, I have fitted soem dohc carbs to my tracker with a little modding (the dohc's are narrower) twin means 2 cyl engine
- rebuild???
100/90-18 on 1.6x18 Rim? 82 XS400SG
i posted a pikkies of a virago which had a rear wheel for the front. if you have wire wheels, then lacing a different rim should present no probs except for any clearance issues you may have!!
Proppa Sclew dliva Daniel san
just swap 'em with allens
BAD DAY!!!!!
Kin 'ell mate, you got a friday bike!! ( ask OG about Friday vehicles )
how does kickstart engage engine...
also note that the engine won't turn over with the clutch disengaged/missing as the kick gear moves the gears through the tranny via the clutch to the main drive pinion at the end of the crank!!
you sure its a 1.6? 1.85 is standard as far as I know!
usually 90/90's, i got a 3:50 x 18 on the front of my tracker, it fits under the front mudgaurd, but I've yet to ride it so i don't know what the handlings like!!
1980 XS400 leaking oil.. pictures .. how screwed am I? lol
rolled off the table and onto the floor. into the kitchen and out of the door. rolled in the garden and under a bush then your little steel ball is nothing but mush.... mush mush!!
Adjusting the valves on my XS400
you don't really need a torque wrench for the screw although it only 6lbs ft so don't go mad!! do it yourself its really easy if a little fiddly, try and buy the angled gauges as they can be manovered easily.
is a 77 xs400 engine swappable into a 78?
As i said all sohc's will fit. if the contacts can be upgraded, then i assume the reverse is true
I've seened a Unicorn Cleatus
no messing there, hate to think if the thing gets caught turning, you'd get a clout then
Vacuum line coming undone
renew the line and put a wire clamp in there to hold it over the nipple
its got the electronic ignition trigger which is usually a later engine (circa 1980) and the engine off a special/heritage type bike due to the rounded barrels. there is a thread in the sticky to convert to electronic ignition if you want to go that route, otherwise sell the trigger mech and revert to contacts! 4G8 engine #?
xs400 engine disassemble question(s)
oil pan? is it the 6 x 6mm screws under the case holding the oil gauze cover? its a tight bugger and with no heads on will come off. Use a rubber mallet to shift it slightly with luck, the screw shafts will be protruding and you can get to weld a nut on to remove.
good to go mate, all sohc's fit!
- Hello
Anyone considered using Lubro Moly?
generally due to the high power to cc ratio, motorbike engines have higher spec oils. no need to add anything, the best you can do is change the oil regularly, save your money towards that!
kitten chasing a piece of string
lovely chune <object width="640" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
1977 Yamaha XS360
yep it was an interim model which was superceded by the xs400, i have the dealers spec on the differences if if you really want me to be anal about it nice looker BTW hammerlo
- Hi There
- Yamaha XS400 Starts ONLY when primed
