drewpy
Everything posted by drewpy
  1. I'm assuming its an enfield
  2. they will fit as this has been mentioned before in this forum changed me sig again
  3. drewpy replied to a post in a topic in Video Section
    that was like squires to me on saturday nite
  4. drewpy replied to blackhat250's topic in General
    anyone seen "on any sunday"? steve mcqeer, dirt riding, flat trackers. cracking film. just do a torrent search!
  5. drewpy replied to Goff's topic in General
    just a temp one to annoy peeps
  6. BTW xs400 boots will fot the 360 as theya re the same size carbs
  7. I used to like "bellie's going to get ya!" advert <object width="640" height="385"><param name="movie" value="http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&amp;hl=en_US"></param><param'>http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=yN_R0J8kU5I?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
  8. its starting to annoy me too
  9. it use to be like that, called letterboxing!
  10. have deep pockets, is the '82 a dohc?
  11. drewpy replied to Stev125's topic in The Bar
    sounds great and its a good buzz riding in a large group
  12. yep, that "place" is called a shop.
  13. seen that before, weird or wat!
  14. that was my exact thoughts when most of you rammed past me. lemmings also sprung to mind
  15. you can use your iphone or smart phone as well as garmin devices
  16. drewpy replied to timtaxi's topic in The Bar
    very nice is that a PSW hardtail? more pikkies please
  17. you have a choice; leave alone and hope that any rubber o ring is ok (if that's the model carb you have) Or remove the plug and have a look while the carb is out. personally I'd remove it and check the contents. I think if you drill a small hole and get a self tapper in there, you should be able to pull the thing out! drewps
  18. yea! I wouldn't ask cynic, he don't use any
  19. been geo-caching for years moniker? why "drewpy" of course got a geocoin that's going round the world. its been to brownsea island then saudi now its over in spain. there's even a cache in Antartica. It takes you to places off the beaten track and normally gives you a bit of history of the area. good heads up BWJ
  20. Managed to fit one of the micro switches inplace of the clamp screw on the lever bracket looks quite smart just got to find a small rubber to fit over the switch ( I might ask Kev!, so Paul said!)
  21. I think I left mine off and I use an inline filter I would use the new one with the new counterpart, mixing old with new is not good . sounds right, i have something similar with a looped clear plastic and it uses a small ball bearing Is the black plastic thing the diaphram? I put ACF50 on the diaphram to stop it cracking and keep the main jet piston clean. (slide!!) drewps some links http://www.obairlann.net/reaper/motorcycle/manometer.html http://www.therevcounter.com/uk-motorbike-forum/15892-diy-twin-carb-tb-balancer.html
  22. drewpy replied to timtaxi's topic in The Bar
    I've already done that for Kev, he just told me to feck orf even did him a pretty picture!!
  23. drewpy replied to timtaxi's topic in The Bar
    use photobucket. upload pikkies there. in photobucket, copy the IMG tags under the pickkie you wanty to post (clue it start with copy it where you normally write. you can still write either side of the IMG tags as normal simplz
