drewpy
Everything posted by drewpy
  1. YOC members strike again
  2. drewpy posted a topic in Video Section
    this is so cool viral but good
  3. drewpy posted a topic in The Bar
    very funny and a good little read http://hyperboleandahalf.blogspot.com/2010/09/party.html
  4. Yo Mofos chek out da vid maaann, t'is wikeed
  5. drewpy replied to spydey98's topic in Yamaha Workshop
    try some bearing retainer. bit like threadlock
  6. drewpy replied to Joeleol's topic in Classics
    looks like the floatey bits will fit as they share the same 4 digit number ( just the model # is different) OTHERWISE THE CARBS ARE A LOT DIFFERENT
  7. drewpy replied to skik's topic in Yamaha Workshop
    could be oil on the disk!! check fluid levels and brake pad wear to be sure
  8. to the YOC joeleol
  9. drewpy replied to Cynic's topic in The Bar
    NW200 better than the TT I think and some cracking roads/ giants causeway etc
  10. on the schematic, one of the white wires eminates from the middle of the stator, that one is not used. black is the negative part of the voltage reg, green the output to the feild coil and brown supply to the voltage regulator.
  11. bloody 'ell, I'll have Kev wanting it!
  12. georgous, and in my fave colour scheme.
  13. drewpy replied to fuff66uk's topic in The Bar
    to the YOC Fuff
  14. white ones are the outputs to the rectifier (stator) and the 2 wires are the regulated 12v input to field coil via the voltage regulator.
  15. I thought of Satin black all over, but its been done to death
  16. looks good vez, busy sunday I'm afraid though
  17. drewpy replied to Cynic's topic in The Bar
    lets just go to the NW 200 and enjoy the criac! then we get get pissed and not worry aboot drink driving!
  18. its NI so part of the uk
  19. nowt wrong with me photoshopping skills, just no point in spending hours on a mock up
  20. why don't you PM each other (its like email, but using the forum facillities)
  21. yea, like the tracker bit on top, food for thought
  22. do a compression check first to see if you have out of balance cylinders. check valve gaps and ignition timing next, to manually adjust the carbs, place a 2 x 2mm bits (with the carbs off) under each butterfly valve and slowly pull the throttle up. the idea is to get the bits to drop at the same height as the butterflies begin to open.
  23. drewpy replied to dave2292's topic in The Bar
    Ciao Dave amd to the YOC
