drewpy
Everything posted by drewpy
  1. drewpy replied to up.yours's topic in The Bar
    buon compleanno, mezzo centro. have a gud 'un
  2. to the YOC revlt
  3. drewpy replied to kir31's topic in Classics
    take your caps lock off, trust me, its considered rude! sohc xs400 will fit straight into the xs250 frame and is lighter to boot. electrics the same had my tea thanks check out the sticky in the classic section re:xs400 the xs frames have a triple backbone, so you'll need to adjust the tunneling to suit the frame.
  4. drewpy replied to micha's topic in Classics
    use a strobe lamp and adjust to the right hand mark when it flashes. LT and RT is for the static setting only!
  5. so long as they are both sohc and have the electronic ignition, i can't forsee any problems. it should be just a straight swap. just have a looksey at the front mountings and see if they are the same. the engines got rubber mounted at the front about 1980
  6. drewpy replied to kir31's topic in Classics
    woah! why the shouting man?
  7. don't condone violence, but he deserved every bit of that!
  8. you've worn them wheels down Kev, I'm sure they were 18" standard
  9. hello
  10. cheers Patricia. top of the 'morn te ya!
  11. could be water which means head gasket failure. was it all re-torqued down after 100 miles or so?
  12. to the YOC stayung
  13. drewpy replied to drewpy's topic in Yamaha Workshop
    I'd appreciate that. I have a sealed reed relay DPST, couple of 330 ohm resistors, and a couple of ceramic caps rated @ 50v. Pillingas has given me good advice up to now, but I'm all for more info! I also managed to get meself a tiny case and mini hobby board for soldering onto. I must be good at soldering as I repaired ny vauxhaull key fob as the battery holder snapped off! cheers drewps
  14. drewpy replied to drewpy's topic in Yamaha Workshop
    every time i've been past its been shuttered up.
  15. found the supplier http://yambits.co.uk/product_info.php?cPath=241_82_358&products_id=1540&osCsid=433s6mm8df34t6e88nfo65p6g1
  16. drewpy replied to up.yours's topic in Video Section
    showed the kids the sigue sigue tune, and they said, thank god we wern't born when that came out. When I said it got to number 1 they howled with laughter! can't say I'm a fan either!!
  17. I have oem keys and there's only 4 number and never heard of a 5th letter. I'm sure there's a thread here where someone can cut keys from the number!
  18. the key number is only 4 digits, check ebay as I'm sure they had key blanks on there not long ago!
  19. £210 !! Merv must have a bid in. he has to round up those crabs of his in something fetching
  20. Bob R Nation
  21. Mike
