drewpy
Everything posted by drewpy
  1. drewpy replied to neversaydie's topic in Reviews
    cool, why not glue some non slip carborundum strips on the lift like they have for steps?
  2. tell him what the correct size is, he can't respond unless he has evidence to support his side
  3. drewpy replied to drewpy's topic in Projects
    I'm leaning towards the clutch now. carbs were balanced and tensioner already adjusted been searching all night and it has the same setup as the divvy. Thrust bearing etc etc I was also having issues changing down but thought it was due to the slop in the linkage. If i pull in the clutch it momentarily disappears too which gives it more weight Also the pin wears behind the basket which connects the oil pump which creates some noise. classic mini roll pin on order think I'm getting there now
  4. never assume people know more than you, especially if you tell them you know nothing. Always do your research first and tell them what you want them to do.
  5. a crap one? have you checked the tyre specs for the bike?
  6. here's a couple of Bolts
  7. its a hollow cylindrical metal object that fills a gap/s (between bearing and swing arm for instance)
  8. drewpy replied to drewpy's topic in Projects
    any xj owners out there? engine sounds like this, some say its normal, but can anyone confirm?
  9. drewpy replied to drewpy's topic in Projects
    ...and it passed (or past as you young'uns would say!) tax it on thursday and use it for a bit and see what needs doing.
  10. loosen the wheel? wtf it needs to be as tight as you can get it 75 ft lbs usually did you lose a spacer?
  11. I see toecutter in there from Mad Max
  12. I watched it all the way through!!!
  13. should given him the bird
  14. good and cheap are not good friends.
  15. erm , put baffles in?
  16. drewpy replied to drewpy's topic in Projects
    FZ went in for its MOT today
  17. drewpy replied to drewpy's topic in Projects
    Ral 2004 orange Ral 6027 light blue Royal Blue for thin stripe between orange stripe and light blue
  18. you've got to watch Rise of the Animals, its so bad its good
  19. I like the 60's honda s800's old celica ST's Datsuns z600 just saying
  20. Took 3 months to make...why?
  21. Duck tales woo hoo
  22. drewpy replied to drewpy's topic in Projects
    rewired the rear of the bike and not too soon either. The fuses fell apart and the PO (not Paul) used those silly blue connectors instead of solder and Jap spade connectors. Also the suspension bush finally arrived today (from Japan) and I rebuilt/fitted the suspension. Yay is moves now went for a little spin and seems to run OK considering its been outside for 3 months. now to get it MOT'd and 6 months Tax and use it a bit and see what else needs doing before it comes off again for a rebuild. Drewps
