drewpy
Everything posted by drewpy
  1. called a parody tout
  2. he was on "that's life" with esther ransom too
  3. you can always do it manually ie put quote tags either side the text your quoting
  4. that brought me here too
  5. Paul can give me a ring when he gets stuck
  6. some motorcycle faux pas kev's fave foamey's mum got him this come again?
  7. or drive up to them and wind your window down
  8. I remember rendering the Utah tea pot and it took 2 days to do
  9. remember dial ups and single speed CD's?
  10. just bypass them by connecting the wires together
  11. hey Mc, sent you a PM mate
  12. AUS OPEN 2015 - Djokovic v Abrams Semi-Final
  13. drewpy replied to drewpy's topic in Projects
    decided to trial fit the R6 shock I got, def doable. make an adapter for the top of the shock to clear and hopefully I can use the YVPS dogbones as the original hits the rebound adhuster. can someone please, if you have a YVPS, measure the swing arm bracket length and inner diameter? someone did a lovely CNC version
  14. Simon you need the link within photobucket, not the top line address Viola!
  15. If you don't find anything, I'd pull the clutch cover off and check that the starter gear to the clutch basket is not loose, that makes a noise. Also the pin behind the basket wears too. do a search on the forum for easy fix for top end make sure the camchain tensioner is working
  16. did you upgrade your browser? tried firefox?
  17. that's because its a Q regarding the forum, your welcome So you upgraded your computer and then blame the site 8.1? I'm sticking with 7 till that version settles down. probably find there may be an update coming for you. Did you try upgrading the browser?
  18. mine's ok, must be your computer
  19. here's a couple of sparks
