orb1998
  1. orb1998 replied to orb1998's topic in Naked
    No problems thanks for that but i contacted a guy on ebay that turned out to be a breakers and they have measured them, so thanks to him i now have cables for a grand cost of less than a fiver The cable length for a YZF750r 1995 is 62 cm or 620mm hope this helps !!!!!!!
  2. orb1998 replied to orb1998's topic in Naked
    I intend to use cable and screw on cable ends, i have seen it done in a couple of forums(a company called venhill have cables and ends, i have used cycle brake cables and had some ends made at work). I have tried the brazing and solder methods and due to capillary action the solder runs onto the cable, so screw type os the way forward. I have all the bits to make the cables now i just require the cable lengths...... i no the legnth for several other bikes after doing a rake loads of searching but not for a YZF750, i was given a dimensions from someone but this was too short. As soon as i have the info i will post it for all !!!! Just need the legnths!!!!!!!!
  3. orb1998 replied to orb1998's topic in Naked
    Anyone help please... still in need of the exup cable lengths from end to end as i have nearly sorted my bike to get it back on the road and this is the last info i need and have looked everywhere Cheers
  4. orb1998 replied to orb1998's topic in Naked
    No not found the length yet so if you wouldn't mind taking your cables off to measure them i would really appreciate the inner cable lengths Many thanks in advance
  5. orb1998 posted a topic in Naked
    Can anyone help... I am after the length of the Exup cables for a YZF750 Mine are missing off my bike and i want to make some new ones but require the length end to end, sorry forgot to add i have the outer cables but its the inner length i'm after many thanks in advance
