wescole
  1. This also happened to my dt125, i checked the spark and there wasnt one. then i was gettin quite annoyed with it and i gave it a little clean around all the electric parts stripped my bike checked all wires to killswitchs etc and taped em up. took the carb off and cleaned that, then my bike was running perfect.
  2. You could take it in to a motobike shop and ask there. good luck, wes
  3. since i got a pitstand it doesnt get stuck even if i leave the petrol on. maybe the standard stand angle is a problem. thanks for your help guys
  4. I also have a dt125, mine hasnt got a reed restricter, maybe yours has. hopefully this helped
  5. i will try that next time it gets stuck thanks
  6. Hi, I have a dt125 fully converted to offroad use, Is it normal for the float valve in the carb to get stuck if I leave the fuel tap on overnight? everytime it gets stuck i have to take the bike apart and drain the carb out. also i have tryed starting my bike up with fuel tap turned off to drain it, this doesnt work. Has anyone had this problem and found a solution please reply thanks. regards, Wes
