EPP
Everything posted by EPP
  1. Yeah, I was wondering if it might be conrod knock. I've just been reading that one way of diagnosing this is to remove the plug cap from each cylinder in turn while the engine is running. The absence of combustion means the piston isn't forced down, so any free play doesn't cause as much (or any) knock. As long as it's mainly one cylinder contributing to the sound, this should isolate it. I'll be giving that a try once I get to work tomorrow morning and the engine's warm. Cheers, Ewan
  2. Cheers Jim, I'm going to have a go at balancing them and see if that cures things. Should the choke be on or off when the actual balancing is done? I'll be sure to post my results! Ewan
  3. The hyvo chain is the cam chain - that right? I did adjust the tension a while back, which reduced a rattle I was getting. It was after I did this that I became aware of the knocking once the engine was warm. How do poorly balanced carbs lead to the cams moving, and what are they knocking against? The carbs have been dismantled and cleaned, but I didn't have the tools to balance them. When you say mix strength, is this the idle mix strength that's adjusted via the pilot screws? cheers
  4. Thanks for letting me know about that. I'll certainly check it out! But I don't think it explains the current noise, as it occurs with the bike stationary, and is in time with the revs. Ewan
  5. It's a 1990 model. Doesn't leak any oil that I can see, and the exhaust is clean. I've not been able to check the oil pressure, but it seeps out of the little bolt that you unscrew at the top of the cylinder to check oil is circulating up to the cylinder head. How would I check the oil lines? That's always been a mystery to me. I've had a look at the cams and there's no sign of wear (although I haven't checked with a micrometer), plus the clearances are fine. I'm wondering if it could be worn springs, or some other part of the valve train... If it's something I can fix myself then I'll probably do it. If it's going to cost a lot then I'll scrap the bike and get a new one Ewan
  6. Hi all, I've been riding my xj600 for a while now, despite a tapping/light knocking noise that's impossible to locate! It isn't there when the engine is cold, but get louder as the engine warms up and can be felt through the bike. It doesn't get worse under load (back brake applied and slipping the clutch), which makes me think it isn't a connecting rod or main bearing. In fact, it might even improve under load (or the noise is just damped somehow). I've been using the 'screwdriver as a stethoscope' method (I think the neighbours are wondering what on earth I'm doing) and listening to various areas. Seems to be strongest around the exhaust valve area of the RH cylinder, but rather confusingly also seems to be quite strong around the top of the alternator cover. I've checked the valve clearances, which are spot on. What other parts of the valve assembly might lead to this kind of noise? I'm particularly interested in the fact it's only noisy when the engine's hot. The bike was stolen and ragged abut a local park before being recovered, so I reckon the engine has been over revved a bit... Cheers, Ewan
  7. EPP replied to smeghead1's topic in Yamaha Workshop
    I've had a lot of luck with ebay for pre-divvy parts. If you need a few things, find someone breaking a whole bike and negotiate a discount for bulk buying! They're sometimes just glad to get rid of it. Ewan
  8. EPP replied to EPP's topic in Yamaha Workshop
    There's a few noises... One is the usual xj600 clutch rattle. I fabricated a replacement pin to reduce the play of of the oil pump drive gear on the back of the clutch basket (which is apparently a common cause) whilst I had the clutch apart to replace the friction plates and clutch springs. Unfortunately this didn't fix it. There also seems to be a rattle from deeper within the transmission mechanism. If you pull the clutch lever in, the clutch rattle goes - it's not the thrust bearing (it's in good condition), I reckon it's the pull rod rattling in it's housing, which goes when under load (from pulling the clutch). If you engage 1st, apply the brakes and release the clutch to biting point to load the engine, all the rattles go very quiet. However, all this seems to independent of the regular knocking noise that appears to come from the crankcase when the engine's hot. The bike's actually with a mechanic now! I demonstrated the noises and stressed it was the knocking noise I was interested in, as I reckoned I knew what was happening in the clutch. He wasn't sure, and I agreed for him to spend an hour looking into it. Phoned today, and all he's done is pull the clutch open again and confirm what I already knew about the pull rod. A total waste of money... The shop said a strip down and rebuild would be the only way to work it out. I'll have a look into getting all the parts together, although i really don't have the time for this at the mo! Already got the workshop manual and have skim read through all the steps. Cheers
  9. Hi all, I am considering the possiblity of an engine rebuild on my XJ600. There's a regular knocking noise coming from (I think) the crankcase that's audible at tickover and even more so using a screwdriver as a 'stethoscope' pressed to the engine. The engine seems to run absuolutely fine, but I'd rather get this sorted before it fails properly. Where can i buy all the bearings/gaskets/etc that I'll need, or should I be giving up on this bike? Cheers! Ewan
  10. Repaired the clutch, refilled the engine with oil and got the bike running today. No rattle!! So it looks like it was the cam chain. Unfortunately, a short way into the test ride I noticed a regular knocking sound coming from the engine, in time with the revs. Could be felt through the bike and heard at tickover, but not audible at higher revs (may just be drowned out). The knocking wasn't there when I first started the bike, only when it had got pretty warm. Got the bike home, and when I listened to the engine it sounded like it was coming from the cylinders (I just put my ear near - have since read about using a screwdriver as a stethascope to help locate the noise more accurately. I'll try this tomorrow). No idea if just one, or more, cylinders involved. I also noticed the engine was hotter than usual, or seemed to be anyway. I had already topped the oil up after running it for a few minutes to fill the filter etc, but it needed another 300-500ml on returning from the test ride, and a vapour rose from the crankcase when the cap was removed - definitely seemed hot! Could this just be the result of low oil? How much below the recommended level would cause overheating? And would overheating lead to the knocking noise? Cheers all, Ewan
  11. I may be barking up the wrong tree entirely, but could it be well-known xj600 clutch rattle caused by the oil drive gear at the back of the clutch cage? Ewan
  12. Yeah, I lined up the marks (I've got the later model that required you to line the C up with the mark on the crankcase). The manual didn't say to loosen the bolt to release the tensioner first - that's the vital bit of info I was missing. I had a hunch it might be necessary, thanks for confirming! I wonder if that will have fixed the rattle. Need to replace some bits of the clutch and refill with oil before I find out...
  13. Valve clearances - fine Cam chain tension - well, it seems pretty tight to me. Can't imagine it slapping around. I've been tinkering with the cam chain adjuster, but I can't see how it changes the tension. It seems to operate as a lock screw for the spring mechanism rather than something that adjusts the tension directly. Am I missing something? I've replaced the dowel pin on the oil drive gear at the back of the clutch. Very little play there now, so hopefully that'll cure the clutch rattle. But seeing as I've not found anything wrong, the rattle that seems to come from the valves will presumably still be there. Any suggestions much appreciated! Ewan
  14. I'll have a go with the redex - can't do any harm... Matty, I think my engine needs a similar amount of attention to yours on startup. Have taken it for a ride and checked the plugs - no fouling, so looks like the engine is breathing properly now as well. However, have now identified a rattling noise from the engine that I'm not happy with (see my other post). One day, I'm going to find out if I actually enjoy riding a motorcycle rather than just taking them apart
  15. I'm getting there with my bike... Exhaust - done Starting - sorted (overhauled carbs, replaced caps and plugs) Brakes - bedding in So, I took it for a ride the other night and noticed the engine was making a kind of buzzing noise, or high frequency rattle, at about 3-4000 revs (I was bedding in the brakes so didn't get much above that). I've since had a listen with the bike in the drive, and it sounds like it's coming from the cam chain or the valves. Seems okay at tickover and just above (where the clutch rattle comes into play - but that's another story). If the engine is revved, the noise kicks in and then recedes as the revs drop. I'm going to adjust the cam chain tension first, then check the valve clearances and valve spring, as suggested in the manual. Bearing in mind the bike was stolen and most likely ragged about the local park before being recovered, what other things might I be looking for? Cheers, Ewan
  16. I replaced the plugs and first signs are good. Took a while to start (probably still working fuel through the system following removal/reinstallation of the carbs) but once fired up it seemed to idle well and was very responsive on the throttle. Not had a chance to ride it yet. Also replaced the air filter - it was pretty mucky, and this might have been causing the engine to run rich. I didn't check the air filter after I bought the bike last November, so I've no idea if had been like this for ages or was fouled up while it was stolen. Assuming the bike continues to run, I'm going to keep an eye on the plugs after each ride. If they get sooty, I'll know it's to do with the jetting in the carbs - probably the secondary (needle) jet... I'm also thinking of putting some redex, or similar, through the engine just to give the carbs a final clean and hopefully remove any crud from the combustion chamber. Anyone got any thoughts on this? Is it a gimmick? A waste of time...? Cheers all, hopefully recording the steps i've taken will be helpful to someone else at some point! Ewan
  17. I'll see what I can do. It's just a matt black finish - not that pretty (but not ugly either) but cheaper than replacement! Should keep me going for a while.
  18. EPP replied to T1A50 London's topic in Yamaha Workshop
    I recently resprayed the exhaust (link section and cans) off my xj600. I removed it from the bike and had it shot blasted clean to take off all the rust and the old finish (cost 25 quid at a local place that specialises in this type of cleaning process). This is very important, as vht paint is not designed to cover rust. The better the surface prep, the better the final result. I handled the exhaust with rubber gloves after it was cleaned, and rubbed it down with carb cleaner to remove all traces of dust etc. Used a can of Halfords own paint per silencer and it went on dead easily. Just build it up in a few coats leaving 15 mins between them. Not sure how it'll hold up in the long run, but good surface prep gives it the best chance of lasting. Ewan
  19. If only things were simple... The engine just would idle properly, so I ended up taking the carbs off and taking them apart. There was quite a lot of crud, and some water, in the float bowls, so everything got a good clean with carb cleaner including all the jets and passages. Reinstalled it and managed to get it started, but now it idles even worse than before! It keeps stalling, and the revs pick up really slowly. Maybe there's still some carb cleaner blocking the pilot air passage or some other passage... I've also taken the plugs out and found they are black and sooty, suggesting the engine had been running rich. That would make sense given that the previous owner found it started fine without choke. How do I adjust the fuel/air mixture? I didn't remove or adjust the pilot screw as it advises against it in the manual, and I assume this only affects the idle mixture. Could this lead to the black plugs, or are they to do with the mixture at high revs? How would I adjust this? I've tried to search for these answers but didn't come up with anything. Cheers, Ewan
  20. Hi all. An update... The problem ended up being with the choke. Whatever those pesky thieves did, they interfered with the choke mechanism so that it wasn't doing doing its job. I was just cranking the engine without the extra fuel getting to the carbs - no wonder it would take ages to catch but finally get running. I thought it might have been a fuel problem, but that didn't seem to explain why it would finally get running and stay running. Sorted the choke, now it seems to start pretty well. Time will tell if it's going to be reliable though. At least I've been out for a short ride to try and bed the new pads in. I think they'll need a few more miles though. The only strange thing is that once the engine is running with the choke on, the revs gradually die away. It requires the odd blip of the throttle until things have warmed up. It wasn't like this before the theft - I could just leave the bike to warm up and push in the choke after a few minutes. It's no big deal, but if anyone knows of anything I should be adjusting then let me know! I got a plug socket through the post, so I'm going to check the plugs for peace of mind. I reckon they'll be okay though. Ewan
  21. Hi Dave, I've already replaced my reg/rec after having the same problem as you - the bike would run for a day or two, then I'd try and start it and lit would be dead. Seemed to sort it right out (a good 14+v across the battery when running), but on my maiden test ride following the repair, I stopped off at my mates house and the bike was nicked! I presume it was ragged about the local park, as it was picked up by the police a few streets away. Anyway, I've been tinkering with it since (that was last November), and the problem is that I don't know exactly what the bike went through! It doesn't start properly even from a car battery, so it can't just be that unfortunately. I'm just having to deal with each new problem as it arises - it's only this weekend that I've got the bike to the point where I can work on getting the engine running again. I only passed my test last November, and this is my first bike, so it's been a baptism of fire! I'd always planned to learn how to maintain it myself, but not as quickly as this...
  22. Just checked the ignition coils - primary and secondary resistance - and the cap resistance. Here's what the manual says: Primary resistance was 2.6 for both coils, which is correct for a pre 1989 xj600. Mine is a 1990... Secondary resistance was around 12k for both coils. No problem there. The cap resistances were approx (from left to right) 9.6k, infinite, 12.2k, 9k. So, one definitely faulty cap, and one with higher than specified resistance. I suppose I need to get the caps replaced. Given that the primary resistance on the coils was the same, I'm guessing they're not faulty and I possibly have the older style. Really want to get the plugs out to have a look.
  23. Checked air filter - a little grubby but nothing that would obstruct air flow. Can't get the plugs out right now - need an 18mm socket (will try and buy one today). I tried draining one of the float bowls, and fuel flowed freely out of it so I think fuel is reaching the carbs. I can also see the fuel in the line coming from the tap if i shine a torch down it. I think I might take the carbs off and give them a clean anyway. Any advice on how to do this? The manual outlines how to perform a complete strip down and rebuild (with rebuild kit) but I was hoping I might be able to avoid this. I may be shopwing my inexperience, but can I get away with spraying a few key parts with carb cleaner? Should I just be using engine oil if decide to squirt a little into the plug holes? Thanks for the advice RE not overworking the starter motor - I don't want to create more trouble!
  24. But even with a car battery it takes a looooong time before anything starts to happen (about a minute or two of repeatedly turning the engine over). I'll have a look at the air filter now. I also need a plug socket so i can get the plugs out to check them. Will also check the ignition components if I can, but the manual suggests building a little tool to help with this, and I might not have the time. Could it be a problem with the carbs if the engine eventually starts going and then runs well?
  25. I'm making progress with my XJ600. Brakes and exhaust are done, and I'm ready to get back on the road... but it was never going to be that easy was it? The engine just turns over until the battery dies, doesn't seem to catch at all. However, if I jump it from a car battery (i know some people would advise against this) the engine will turn over repeatedly until it just begins to catch, and eventually it will splutter into life. Once going, it warms up fine and seems to run well, then restarts immediately from the bike battery after being shut off. So, I'm wondering what this might be all about. Could it be that fuel is taking ages to get the engine? Could the carbs have got gummed up while the bike has been laid up (but presumably this would mean it wouldn't start at all)? Could it be something electrical? The thing I find strange is that it will finally get going and run well after that. Any suggestions?
