leggy
  1. has any had any success with a carb upgrade on a dtr. I've looked at some full power tzr/tdr carbs, vhsa32gsvs, however, they seem to have 2 extra cables coming out of them.
  2. do all the things on the dtr.net website. Have juts done all of these to my 02 dtr , with a good improvement. Trickiest bit, was activating the servo operated powervalve. mine was deativated, so follow the notes for the earlier model. Powervalve effectively has 4 settings, off, on a bit, on full, and runs like a pig. Make sure alignment marker is correct, then take the plastic bit that drives the powervalve off, you' ll see that on the back of the insert only allows the powervale to fit in 4 different positions. trial and error to find the correct one. When you've got it right, you'll know.
  3. hello, can't resist squeezing some more power from my 02 DTR 125, i've done the usual derestrictions, trouble is I'm 18 stone, so the bike struggles a bit. Has anyone 1) used a athena 170 kit, did it make much of a difference 2) Whats the max cc you can rebore the barrel to, what difference did it make 3) Are there any other engines or top ends that will fit with little modification 4) Are there any mods you've tried, that made a difference dieting is not an option. thanks
