rsx yamaha
Everything posted by rsx yamaha
  1. hi i gladly got the side cover of and i think my points are weared out the bottom point is flat comper to the top point + it was sparking where the points are so is it worth it geting some new points and the bottom round bit at bottom to ie looks like a battery as it says in manual if this sparks here replace points and this metal round but in side the casing ie its under the points
  2. hi there no not yet due to other owner before me has welded the gear peg ie got to clean the metal pole so i can take the side cover of
  3. ive done that what you said but i cant get no spark is there points in the engine to sort out? if so what gap does it need to make them work
  4. heres a engine code pic and the bike pic i said which is not a standed yamaha rxs /rx 100 bike!
  5. mines defo got the sky blue so is this a rxs100 or rs100 i know when i got it it had a rusty coil with a black wire going to coil but with a cut in the black wire with a rocker swtich on
  6. hello i just brought a yamaha rxs 100 ive brought a new battery/ spark plug ignition coil/rectifier now my hard part is the only wireing i have is from the engine its self ie i wanted to do a field bike as i have a other swing arm and its lowed at the rear and got a nobby rear tyre on now my hard part is what wire goes where to get a spark i have 5 wire ie 1.black 2.red/green 3.blue 4.yellow 5.green plus in the manual it says on the wires from the engine theres a code saying SB what does that mean? does any one know how i could wire it up useing the new bits i got ie the bloke at the motor bike shop said i needed these bits but i dont need lights etc i just want to have a rocker switch so i can turn it of to cut the engine out etc if you know what i mean hopefully some one can kindy share some light:) cheers rob
