kboy
Everything posted by kboy
  1. Thanks for the reply. In response number 2 cylinder does not fire and the header pipe remains cold. I have taken of the carbs and cleaned them out , problem still exist. I changed the plugs and no change. I tool the plug out and noted that the plug was wet. There is fuel in the carb bowl. So i thought that it might be the coil pack so i swopped the coil packs over and the problem is still there . I was going to buy a compression tester and see if there was compression in cylinder two . Any advice greatly appreciated.
  2. my bike is driving me nuts. About a week ago number 3 cylinder went down. Soooooooo i changed the plugs cleaned the carbs and air filter. there is fuel in the float bowl , when i take the plug out its wet. So today i switched the coil packs over and the problem still exist. Can anyone chip in with anything else I should look at , cheers very much
  3. I was wondering if it is possible to change my vacum fuel pump on my 93 600 diversion to an electric one with out too much grief. any help appreciated
  4. i have 93 600 diversion which has developed a fault which is cylinder 2 has stoped working ie exhaust downpipe is cold. I have checked the spark and fuel in the carb bowl and both are good any ideas pls. keith
