growls
Everything posted by growls
  1. Can I simply fit a classic read mudguard instead of my customs plastic one or is there more work involved?
  2. Anybody know where I can get a kit and anything about fitting one. I have heard correcly setting it up is a skilled task. cheers
  3. ok its starting at least, woud crap in the carbs explain why its runnign like a dog and got very bad dead spots in the throttle plus spluttering and backfiring like its about to explode ? Im confused mechanically its had nothign done to it except being stood still.
  4. AIS
    growls posted a topic in Yamaha Customs
    do all vstars come with an ais system as standard? My xvs 400 dosnt have one and I wasnt just wondering if a previous owner had removed it or it was never fitted. cheers
  5. It's ALIVVE!!!! - sort of nearly mayb. at least go the engine to fire for a while there may be other problems as it was spluttering and back fireing and dying when you opneed the throttle but at least theres progress.
  6. thats on the list of todays jobs , assumming her indoors dosnt find me something productive to do like go shopping.
  7. Thanks for the offer , but Im down south from you in pie eater country. Just wondering if i can someone with one would bunging it in a ultrasonuc cleaner work. to save me having to take it to bits. cheers
  8. it's had new plugs , found a video on you tube on xvs carbs , well try cleaning them this week end. more than likely I will have to buy another set of carbs!
  9. sounds like a plan anybody got a link to how to do that for numpties ?
  10. Ok it stopped running, then I was ill so it's been standing for a while and it wont start. Hooked it up to the car battery today just in case the battery was duffy even though it said it was charged. There is a spark as I tested the plugs against the engine casing. There is fuel going as far as the carbs as the pump appears to be working at least it was pumping fuel into a bucket when I disconnected the house into a bucket. It simply wont catch though even with choke. The carb needles dont seem to be sliding when we tried a little fuel into the top of them. As far as I can see fuel either isnt going past the carbs or I havent a clue. Any one got any ideas if it is the carbs any idea what it is likely to be *? cheers *side stand switch even though I have pushed the switch in
  11. Thanks, Ill give all those things a try when I get some dry weather and rid of man flu.
  12. Not really a lot more to say. you turn the key neutral light comes on & the amber oil can light whilst it goes 'vrrrr' for a while, then goes out. I give it a little choke and then press start. starter motor tries to start but it seems like the engine never fires. ( I did fully charge the battery). Not mechanically minded. Guess Ill just have to shoot the wee thing.
  13. yup your right more than one problem tis dead Jim dead Jim
  14. thanks for the info we shall find out if there is more problem tommorrow. I do know the neutral light is on and the starter motors trying hard just not firing.
  15. After years of never failing to start, my 400 has stopped working, I may have forgotten to feed the hamster again but I suspect this time it's the side stand switch. The little 'T' shaped part isn't making contact with the side stand. Can any one tell me if it is supposed to be pushed in when the stand is up or completely out. I am guessing they are the same on both the 400/650 model as it uses the same frame etc. Thanks
  16. I know what a huoniao is, I own one to
  17. cheers,thats good enough thanks.
  18. Can anyone tell me how wide the Xvs125/250 rear mudguard are? thanks
  19. howdy, how many beer tokens would you like for the light?
  20. Well according to Howmanyleft.com there are only 2 xvs 400 taxed/sorned in the country. There sone that appears on ebay for sale ever so often but is over priced and mine. The 400 puts out 33bhp new and is basically the same bike as the 650 custom. The difference being the 650 has a bigger engine bore and piston stroke to give it the extra 6bhp.
  21. Got up to find some one had tried to remove my front bake caliper and given up when it had jammed against the disk. AThe problem is its damaged one of the brake pistons. DOes any one know if the XVS 400CC piston calipers are the same as the uk 650cc? cheers
  22. growls replied to Leatherat's topic in Yamaha Customs
    I though they were classed as a naked bike / street fighter type rather than a custom.
  23. growls replied to Dlloyd79's topic in Classics
    bung a politician 30 odd grand.
  24. seek advice for some who knows what they are talking about but you may also be able to fit a slightly wider tire to go with the smaller seat.
  25. Hi,would be gratefull if any one could answer the following questions as im buliding a small none xvs project bike but would like the classic rear fender shape. what are the dimensions of the rear fender and is it made of metal? cheers
