big bike test
Try not to worry too much about the swerve test, if you do what your taught you will be fine! If I can pass anyone can, be calm, get trained, be safe and you will be sorted!
Fazer buying advice
- FZ1 Advice
I would do an hpi check to put your mind at rest or an independant check you may well have a bargain!- Fazer buying advice
Just a little advice required, I am due to sit my mod 2 soon and I'm thinking of my first big bike, does this seem a viable option and what to look for when viewing it. thanks Yamaha FZS Fazer 600. 2003. 22000 Miles. Full MOT on sale. Scottoiler. Datatagged £1999 from glasgow- Mod 1 fail
Thanks for all the replies, I have a full days training on the day before my test to sharpen up the lifesavers, indicators etc!- Mod 1 fail
Passed today, no minors! Mod 2 awaits! cheers Fraz- Mod 1 fail
thank you for the advice, much appreciated, Fazer or xj6 awaits when I pass!- Mod 1 fail
Failed the Mod 1 today, clipped a cone on the swerve and avoid but my nerves where totally gone, sick as a parrot!- heated grips on r125
Thanks for the advice!- heated grips on r125
Been given a set of oxford hot grips(new) and having read the fitting instructions the recommend fitting straight to the battery, I'm not sure about this, can they be fitted via the ignition? Thanks- Yamaha R125 or Aprilia RS125
I'd go for the Yam everyday of the week, bear in mind its a 125 and its a crackin bike to use as a stepping stone!- clutch drag on 2009 YZF R125 Yamaha?
I've had the same bike for 6 months and had no issue with the clutch other than a minor adjustment to lever. I would return it to the dealer as its under warranty. let us know how you get on!- yzf r125 crash roller,
job done, fitted today....doddle- yzf r125 crash roller,
Just ordered a set, can anyone offer any fitting advice? Thanks!- YZF R-125
- FZ1 Advice
fraz24
Joined
Last visited
