Everything posted by Twin Shock
Trying to start 72 RT1 360 with no key
- What year yz80 engine # is this?
What ever you can get it for $450 or less.That looks like a low hour bike.- Making on Documentary on the Yamaha DT125 from 1968-present
Actually Yamaha first introduced the DT 125 in 1974, the prior 125cc Enduro models were AT. Their production ran from 1969-1973.- brake rod adjusting pin
You need the wing nut you highlighted.- mini enduro help
Yes, the european version. Not sure how many countries got the low fender version.- DT 400 Magneto
- Any Mini Enduro JT1/JT2 guru's out there?
Looks like a JT2, 1972 Yamaha Mini Enduro 60cc- Any Mini Enduro JT1/JT2 guru's out there?
Try posting the picture again, I don't see one.- RT1 intake and carb....
It's your call on the reed assembly.If you are doing a proper restoration change it back to piston port. But make sure you do connect the carburator to an air filter some how.- dt175 front end
You can put the front end on your bike, just remove the triple tee and install it into your steering neck. I am using a MX 360 front end on my 125 and 175.In other words the whole front assembly.- Which WR ???
I certainly like mine,When you dial in the suspension and change the tires you can fly off road. The bike is very respectable on the street as well.Makes max power about 10,000 rpm.- Which WR ???
Here is the U.S.the WR 25OR is the only one of the group legal for operation on public roads. I have one and love it. The original tires on the bike are more suited for road use.- 1974 DT175 - Worth restoring?
Yes,that bike is pretty rough.I think it is just a parts bike.Would be for me anyway.- 1974 DT175 - Worth restoring?
Yes.- '74 250 MX fork springs
Here is your answer.- 1973 Yamaha 80 identification
First year GT80, looks to be a good one.- 1973 MX175
There is no such model, You probably have a 1974. The CDI from a 1974/75 models will work only. You might just want to go with a new PVL Ignition. Even if you find replacement parts they are still old.- Downshift without clutch (WR 450)
- 1975 yz 125 b
You can find the airbox on E BAY often. The 74 and 75 MX125 and MX 175 use the same air box.You will see the inner rear fender and the air box riveted to it.- 1975 yz 125 b
$500 To $800. 1976 YZ 125C and YZ 125X were first year monoshocks. The 76 C was introduced in 1975 but was a 76 model.- YZ80E??
- 1975 yz 125 b
The 1975 YZ 125 was a Twinshock, the 250 and 360 were first year monoshock bikes.The only differnce in the 74 and 75 YZ 125 is the color.- 1975 yz 125 b
The stock front rim is 21 inches. Rare bike, keep it or sell it to me.- informations 175 CT1
Make it look like one, parts on on EBAY.- 74 DT 125 Front Fender
The color is crystal silver. - What year yz80 engine # is this?
