wild foamy
  1. if it makes a difference i reset my idle mixture screw, was something like 5 or 6 turns out and a bitch to start when cold, so i reset it to 1.5 turns and now it starts first kick but bogs down at low speed (slight tinkering needed methink) bike hasnt overheated for a while now, and im usually thrashing the bollocks off it in every gear when im out with mates...
  2. wild foamy replied to Jmac's topic in Yamabyss
    Whats in the box that always rocks? ... its a foamy... and whats that foamy's got?... ... its a HAYNES MANUAL
  3. wild foamy replied to mits007's topic in The Bar
    what, dont like the MT-03 so decided to throw it down the road? .
  4. hillclimb
  5. i remember seeing an article in a magazine some time ago which lists different animals and how they are likely to react when they are in the road (and thus how best to deal with them) example, Deer tend to shoot straight across the road so its best to go behind them. however, phesants prefer walking out to the middle of the road and then running back again, so its advisable to go infront of them. not sure how true that advice is, and i wouldnt like to try it myself...
  6. pissing with rain
  7. use an automotive realy, as mentioned above. would be a good idea to wire the realy across the field current from your alternator so that the relay is only live when the engine is running
  8. Foamy for prime minister!. faster mopeds, later bedtimes and a two stroke pump at every petrol station
  9. Mobylette
  10. Marriage
  11. wild foamy replied to kennyr6's topic in The Bar
    actually mine came from currys, i boguht hte ex-display model and because i worked there at the time i ended up getting a huge discount for non-pristine and staff discount
  12. apparently gordon brown is making them pay it all back, but i still doubt they will. why do they do it?, because they can, and nobody will do anything to stop them.
  13. wild foamy replied to kennyr6's topic in The Bar
    i got a Binatone Carrera X350 from work for £30 (staff discount and non-pristine discount) and put it in a freezer bag, it works well and has a decent touch screen which can be used with gloves, but the battery life is only about an hour so you need to have it plugged in to a 12v system, and my DT is 6v so its not the best.
  14. wild foamy replied to mits007's topic in The Bar
    i can still ride mine wherever i like 'cus i got waterproofs and knobbly tyres is no fun in the pissing rain though. nothing like having a warm sunny day when you meet up with some mates and heat up the planet a little...
  15. erm, this bike has deffo got CDI as standard... no points to screw around with, replacement CDI units are available on ebay, ive also got the original DT50MX (UK) publication brocheure which states the Ignition as being CDI. my DT is not an import,
  16. That looks suspiciously like a jawa... or possibly a minsk
  17. nah im using the stock CDI and mag
  18. speed bump
  19. its the fastest 50 then... 'Zuki RMX is a spanish import
  20. Motorbikes
  21. Hangover
