wild foamy
  1. emailed the site owner and he says it comes with the head and gasket (everything together). as for things like exhausts and carbs, i was considering replacing the stock ones with DT80 parts (as i understand it, they are similar engines) but finding said parts is a different can of worms altogether... but now i think of it, by the time ive bought all the right kit i would be nearing the £300 mark before its all complete-ish, on a bike this old i doubt it would be really worth it seeing as i will be going to a 125 next year, 60cc will probably do just fine (and its £100 cheaper )
  2. Result, polini 45mm 70cc Big bore kit £158 posted 60cc is only £57 though... but theres no replacement for displacement ive got £200 to spare on upgrades at the moment though (maybe more if i can sell some of my stuff off), so i will have to spend wisely...
  3. what year is it?. have a look around this site for spare parts and the like BitzforBikes
  4. there should be a small hole through the centra of the pilot jet just like in the main jet (albeit the pilot jet will be smaller) My DT50MX, for example, has a stock .84 main jet and a .54 pilot jet
  5. wont it be expensive to get a 70cc kit over from the Netherlands?, ive thought about the CDI kit but am not sure about how benificial it would be.
  6. hi there thanks for the advice, i cant seem to find a 70cc or 80cc big bore kit anywere, only a 60cc so that will have to do for now. am also jetting the carb and fitting a K&N style air filter to help it breathe a bit better
  7. hi everyone. my question is, would it be possible to fit a DT80 piston and barrel into a 50 sized engine, seeing as they are similar engines (despite the size) also, anyone know where i can get a set of DT80 downpipes to help my yammy breathe a bit better? - Steve
  8. wow, now THAT is a bike... how did you get those panels?, i assume they are all hand-made yes?. if only i could make my DT50 look like that... Hmm... the thoughts are flowing now
  9. hi everyone. am beginning to consider a big bore kit for my Yamaha DT50MX (1990) but would like to know the facts before i do. i already have an aftermarket exhaust can (original expansion chamber though) and will be fitting a performance air filter soon. so far i can only find 60cc big bore kits but i was wanting to get at least 70cc or possibly 80cc (which i cant seem to find the kits for) so does anybody know a good UK supplier that does them?. and because of the extra power would i need a new crankshaft? (if so, where can i find them?) and also, to cope with the extra capacity im going to need to re-jet the carb which i can do no problem, but would i need a bigger carb aswell?) aint easy finding good mods for this old bike - Steve
  10. having read-up on the dragster posts i now understand the concept of jetting and plug chopping. im familiar with fuel mixtures and the like as ive been flying i.c. powered model aircraft for a good few years and did i.c. powered monster trucks several years before, we often checked the glow plug for a healthy dark-grey head and examined the coil to see if it had gone white (indicating a lean run) and adjusted the needle-valve mixture accordingly. another way i used to tune my planes was to set the mixture slightly rich and run the engine up gradually to full power, then cut the throttle and immediately open it again, if the engine hesitated i would lean it out and try again, if the engine cut out or maxed out RPM before full throttle it was often too lean. also i used exhaust smoke as an indicator, excessive smoke would usually be caused by a rich mixture and little/no exhaust smoke meant it was too lean, do these same theories apply to petrol powered two strokes? (all mine were methanol powered two strokes) - Steve
  11. im not sure i understand a "plug chop" i havent had this from new but the engine is the same as it was in 1990 (apart from the rebuild), will have to look up the stock size and go from there will new jetting do anything to the speed/power output of the bike and is it wasted without buying a big-bore kit to use it with? (which i dont really want to do because then it wouldnt be a 50cc)
  12. hi again. will keep a lookout for a slightly larger sprocket and see how i go from there. what about things like air filters and carb jetting? ive found some decent air filtes for £6 a go which doesnt seem to bad if it will help the little peashooter breathe better Air Filters
  13. hi everyone ive got a 1990 DT50 that i want to get a bit more speed out of, i don't particularly want to start moddingthe engine as it is vintage and i would like to keep it fairly stock. (am already running an upgraded exhaust can though) what gearing would be better for more speed?, im not particularly heavy (about 10st) and dont mind sacrificing a bit of acceleration for a bit more top-end speed have attached a picture, not sure why, but i like the bike thanks and regards Steve
