wild foamy
  1. going by the diagram i would say that the cone on the end of the intake is to restrict the air flow into the engine, removing it would increase the airflow and most likely require an up-jetting to compensate and prevent the bike running lean
  2. BWJ, i could have told you that for free
  3. trust me the Jawa is full of rust, plan is to get the frame cleaned and powdercoated when i have the time/money... maybe when im at RAF cosford trouble is nobody seems to be breaking the older DTs, ive seena few of the newer model swingarms but no older ones :\
  4. thanks for the reply but i think the TZR and DT125 frames (and most probably swingarms) are very different from the DT50MX one, im concentrating on repairing it to get it through its MOT (even though the MOT isnt until november)
  5. wild foamy replied to Ski-Dennis's topic in The Bar
    drill it out or grind the weld out with a rotary tool (Dremel) i had to do this last week on a mate Leo vince exhaust for his beneli
  6. hi everyone. took my rear wheel off last week to change the brake shoes and noticed that on my swingarm there it has rusted (almost completely through) on the upright support that connects to the monoshock, ive had a look on ebay for a replacement arm but they seem to be few and far between (not to mention expensive) so it looks like i will have to repair it as best i can. i have basic knowledge of welding, but is there any specific measures i need to take to patch up the swingarm? (seems to be thin) regards Steve
  7. unfortunately this is something that most of the smaller bikes suffer from, including most modern mopeds. the headlight brightness will vary according to engine speed because at low revs there is less electricity being generated to power the headlight, wheras at higher RPMs there is more being generated and the headlight is lit sufficiently. on my DT50 at idle the headlight is very dim, but once im riding i dont tend to realise it
  8. Squids FTL :\
  9. oh my bad, i meant Ttaskmaster, i wouldnt think you would appreciate BWJ turning what you said into one big inuendo though he's scottish, so he is allowed a certain degree of lunacy
  10. ooh, i dont think barwell will like that!, you better edit it quickly, he's 'arder than a coffin nail so its wise to stay on his good side
  11. Foamy for prime minister!, for a two stroke pump at every petrol station and later bedtimes for all!
  12. sounds like a specialist part tbh, or maybe you could try fitting the spring of similar length from a heavier race bike?
  13. wild foamy replied to Goff's topic in General
    you "ride" a trike, as it is not technically a car and is a 3-wheeled bike of sorts im surprised Goff can reach the pegs/pedals on that thing, it looks massif!
  14. have you tried richening your idle mixture screw?
  15. fekin 'el, your spelling is worse than barkwindjammers
  16. and mine will call the army, wooooooo!
  17. okay then i will. Hahaha, lol, rofl, pmsl, lmfao
  18. is that what you call it?, sounds a bit brokeback mountain to me
  19. wild foamy replied to Janie's topic in The Bar
    ive said it before and i'll say it again, youve been smoking something a bit too strong
  20. wild foamy replied to Janie's topic in The Bar
  21. why not take it to your local dealer and ask them to have a look at it if its under warranty?
  22. im not familiar with that particular bike so i cant comment on how easy it will be to change them, i dont think it is a common problem but its not unheard of
  23. could be wear in the selector forks? :s
  24. why not take a short film clip to savour the moment?
  25. did you overfill the crankcase with oil?, consult your haynes manual for the correct measurement, my manual even has a diagram and measurements for making a "dipstick" to check the oil level
