Ayjay
  1. Ayjay posted a topic in The Bar
    Hi Anyone know what after market / different front calipers will fit a 4xv 5 jj R1 ? thanks
  2. Hi was thinking this would be the best place for info on yamaha's right? well does anyone know if the front disc's and calipers form a 98-91 v max would fit a 5eb 01 model r6? strange question i know but bear with me abit .
  3. Ayjay replied to gibsog's topic in Yamaha Workshop
    maybe sucking air in, check the carb inlet rubbers for leaks / cracks
  4. brush them off with wire brush/ sandpaper you can use brake cleaner to remover the dust, then spray with either plasti kote woodstove or barb e que paint, i have used this method many times and found it the best, well other than stainless pipes.
  5. Ayjay posted a topic in Yamaha Workshop
    Hi my aerox 50 has a good spark plenty of compression and fuel but will not fire up, whats wrong? is it sparking at the wrong time? what else could be wrong? hope someone here can help> thanks Ayjay
  6. Ayjay posted a topic in The Bar
    Hi can anyone tell me the base suspension settings of a 1994 YZF 750' thanks
