Cynic
Everything posted by Cynic
  1. clutch has stuck together thats all. Rocking in fitzt may fix it. After 4 years prob be. etter to whip off the engine case and separate the plates by hand.
  2. That could be fun. Less motorway dual stuff is fine with me.
  3. Same as Dirty.. 3inch heels.
  4. Same distance for me Kev. Are you goibg straight up the A1 Elvis. If so we could meet up somewhere. I will be coming from Northampton and would sooner stay off the dull stuff. At least for a while. I generally mess about cross country and end up on the A1 around Grantham ish. Need fuel too normally.
  5. If done properly no. Done badly it can cause premature issues with the selector forks. But you need to be proper ham fisted to cause that.
  6. Cynic replied to elsie125's topic in Projects
    10w isnt that a powervalve motor.
  7. The upshift needs more rpm and positive movements with the lever. Wait till the bike is on power above maybe 7 or 8 thosand and press firmly on the lever. When you shut the throttle breifly the gear will change. Try this......er on a private road eh. Pull off get 1st out the way then wide open throttle. To the stops then let the limiter cut the power so you shift, same pressure on the lever. I gaurantee you will never have had your bike accellerate that fast.
  8. For a mile i'd walk. So are you going to be yet another example ignoring cycle paths and risking death by truck. By riding alongside the cycleroutes on the road.
  9. Damn multiple threads. Been and done Andy.
  10. Keep it up. Most dt tuning stories are depressingly uninspired. Yours is a real treat. Subtle but very much sympathetically modified to improve the bike as a whole. Well excecuted too. I have always wondered if a LH barrel from a tzr 250 would work? Looks close.
  11. No worries. Life aint fair. You either give up or deal with it eh. Don't do giving up......
  12. I feel for yamhead. That MRSA has taken people from my own family. I had to watch it destroy my mother in law, and nearly my missus as she struggled basically watching her mum die a bit at a time over 6 months. Brings a tear to my eye even now. So I thank you not to throw those kind of statements around I know exactly what yamheads family will be going through. God knows he will need all the help he can get to get through it. But it dont alter the fact that about 30 to 40mile is about as far as I have got up to now and still cant ride the dt. Seeing as I was told I may have to stop riding altogether getting to Squires is quite a bonus.
  13. Booked the time off long ago. Dont know if the arm will cope but hey no points for giving up early.... I'll be there Friday.
  14. The upchange is easy. For the downchange you need the revs much lower than you expect. Just above idle if you can manage it. I got a unit and trailer back from plymouth without a clutch. Thats a 16speed 400hp truck and trailer. Admittedly empty but still a challenge. Fitters wouldnt believe it till they checked the time on the fault code.....
  15. Steel that has rusted in situ firming small pinholes blocked by rust. The paint prep will have cleaned them out. Por 15 or similar ethanol proof sealer will permanantly fix it. I had to do the tank on my tdr. I could not risk the paint on that either as it was mint and original.
  16. http://www.ebay.co.uk/itm/390185333984?redirect=mobile This looks much better. Far better quality. Up .5 for rebore. The wemoto is cheap pattern part. Will work but will not perform as well.
  17. Bit late. You only posted it at 11. That will leak. Been there done it. It will also leak again elsewhere. You really are wasting your time.
  18. Wont work. The tank is compromised your only option is to seal it with, and this is important. An ethanol proof lining treatment. Anything else and you will be chasing leaks as the metal has been damaged by water and ethanol. The upside is the paint will be fine save the current leak spot.
  19. Not an expert but my understanding is the OLD as in f g plate dt125s were the ones that were restricted. Boy they flew. The latest ones are making the power they are designed to and you are actually tuning it rather than finding trapped power. All you may actually be doing is stacking what power you have in a smaller band so it FEELS quick. But not making more. That is most deffinately the effect of disconnectIng the pv Do a search tuning dts has been done extensively. Airhead ran a comprehensive thread about it a while ago.
  20. Back in the days of steam I cut the inlet rubber on my dt175 and fitted the, at the time, sooper dooper fibre reeds. Know whats in it now? Stock rubber and reeds and it runs a darn sight better for it.
  21. 2 seconds on google turns up this http://www.bikepoint.com.au/reviews/2002/enduro/vor/530en/vor-en530-14103
  22. Moved to workshop.. Might want to say hi with a bit about yourself.
  23. Dont be a mug. Rare and very quick with minimal hours as a swap for a ratty old 109. Walk away........Its either nicked or broke.
  24. Sure its not Race and Enduro...
