deverett666
Everything posted by deverett666
  1. Yeah, only happens on dipped. Main beam works works without fault and i have taken to doing the same as Maggerz, running on main beam. Was going to change the bulb to see if that helped but i can't see a fault in the present one. Cheers
  2. Hi, Yeah that is basically what i mean. Very annoying problem. I had the garage i usually use tell me it might be the regulator or rectifier(???) or an earthing problem. They weren't very helpful.
  3. Hi, Having problems with my YBR Lights. Main Beam works perfectly but headlight has an intermittent fault which make the light appear to flash, checked the bulb and connections as best i can and cleaned the terminals. Doesn't happen all the time which makes it even more frustrating, local garage say they can't find any thing wrong. Anybody else had these issues and can you help resolve the problems Cheers
