bonzoid60
  1. My two cents, for what it,s worth. Actively encourage him to buy the Mille. Tell him it,s an absolutely rock-solid, unburstable machine. When he discovers the truth, it,ll put him off bikes for life.....problem solved!
  2. Gixxer 1000 in there....early noughties?...
  3. Hi folks, A friend of mine's got a YZF 750 that he's running in Classic Superbike racing. Lately it's been acting up: starts & idles fine but refuses to take full throttle, popping & banging on the overrun, rev counter needle jumping about. At a recent meeting the problem was particularly bad, forcing a retirement. Back in the pits the plugs were changed, EXUP valve disconnected & wired open, problem still persisted. A faulty ignition pickup,s been suggested, any ideas?
  4. bonzoid60 replied to drewpy's topic in Random
    Now I know how Syd Barrett felt.....
  5. Kubrick would turn in his grave, were they drunk?......
  6. Sweet!......Irish bike (i.e. originally sold/registered in Ireland)?.....
  7. Must have been repainted at some stage assuming it's an otiginal XJR frame. All XJR frames were black.
  8. Been having a bit of bother with the YZF lately. Bike starts fine, idles fine & runs fine up to 4-5000 rpm. Beyond that point it feels flat & struggles to rev out. Rev counter needle jumps to 9000 rpm, drops to 3000 rpm & then to zero. Sticking EXUP valve? Fuelling issue? Any ideas?...I know the rev counter movements are a sort of diagnostic code but what does this particular movement signify? Any help appreciated.
  9. Worst ride? A BSA C11 that belonged to friend of mine. Slow as a funeral, non-existant brakes & it was painted that horrible maroon colour! The only bike I,ve ever ridden that had absolutely no redeeming features what so ever.....
  10. Besides side reflectors on front forks & rear mudguard, not a lot really. Keep an eye on oil level as they like a drink! Strip/clean/lube EXUP valve. Worth replacing emulsion tubes too, if it hasn,t been done already as they will wear...
  11. bonzoid60 replied to a post in a topic in General
    Started my biking career 30 years ago this month! Yamaha DT125MX Yamaha XT500 Yamaha SRX600 Yamaha TRX850 Yamaha FZS400 Fazer Yamaha MT-03 Yamaha FZR600R Yamaha YZF750R. Yes, you could say I,ve got an affinity for the three tuning forks brand...
  12. Hi, I,ve got a US import YZF 750. It,s got three wires to the front indicators. Indicators light up when ignition is on. Unlike other YZFs, there is no on/off switch for the headlights (L/H light is dipped beam, both headlights on is main beam). EXUP valve doesn,t rotate when igniton is turned on.p.s. Disconnecting blue wires does away with indicators on. Hope this helps.
  13. Engine will need rebuild, crank seals will be shot, etc. At that price, buy it! Plenty of parts/advice available. An original matching numbers LC will only rise in value!
  14. Quick question, which is the correct NGK plug for a 1987 SRX 400, DPR7EA9 or DPR8EA9?
  15. I,m presuming from your post that you dropped the bike on its left hand side....is the gear lever bent? Any other external damage? More detailed info?....
