mxrider
  1. hello all ,can any one please help?:i have a dt mx 1981 i have put a yz 1979 head and barrel on it ,and the bike runs well.im looking for a flywheel and stator plate that would fit that year,,,or a compltete engine many thanks also looking for a fuel tank
  2. hello ,i have a dt 125 mx ,with a 1979 yz engine,.i went to ken hall motocross at the weekend an noticed that a lot of the bikes ,,twin shock had boost bottles coming from the reed block,,,,,why?????i ,if they serve to add more power i was thinking of putting an early lc reed block on a dt mx barrel,as they had as said bottle.do they increase power. cheers
  3. mxrider replied to mxrider's topic in Yamaha Workshop
    ok i will let you know ,I call his work shop from the no ,on his web site ,www.stan stephens .co.uk.i was quoted £140,that would inclued the head and they would do the sqwish band!!! and you can have it ported to any style i:e low mid or high range. anyway i will keep yiu informed
  4. mxrider replied to mxrider's topic in Yamaha Workshop
    o.. and any idea on timing!! i thought it might pre detonate???but was told it will give a bigger power band??
  5. mxrider replied to mxrider's topic in Yamaha Workshop
    hello thanks for the reply,i did look at the link.mm thats a lot of work,,,i will look at the jet,not to sure of size would that make a big change?? im thinking of having the barrel stan stephens ..tuned ??
  6. hello paul do you still have your dt???????
  7. mxrider posted a topic in Yamaha Workshop
    Hello all ,,,,,could any put im the right picture?????,ihave a dt mx ,i have raised the top of the exaust port ...all is ok, a bit more mid boost..i have a gianeli exhaust ,trying to get a bit more pwer out of the engine,,,i have been told i could advance the timing !!!!!!COULD THIS BE A GOOD OR BAD IDEA ??,does any one have any more sugestions that are proven on there dt.....thanks for reading ,, regards mx rider
