joemac
  1. Hi Nev Thanks for the reply mate. Reading back on the thread i didnt make myself clear, sorry, I switched it off it was running fine....... Just back in from working at it and the starter started to turn again ,lol, hope I've got away with it. As the batteries flat it turned slowly but turned. I'm starting to really suspect the battery at this point. It reads fine on the mm but you get about 10x 2 sec turns of the starter and the batteries dead again. I use the optimser all the time to re charge it. I am reluctant to put the car battery back on...think ill get a battery tomorrow. I took the coils off and cleaned the terminals along with the cdi. Im also starting to wonder does the bike need a good battery to work on the kick? The carbs are defo ok except the float level is at 14mm instead of the 15 to 18 mm spec but i cant see that being a problem. You cant adjust the floats like a proper bike u need to buy new ones so this will have to wait till i get near the menders.
  2. Hi guys hope some of you can help. We've had this Scooter in the garage for about a year now since it stopped going a year ago. drained tank, new fuel, new starter motor, new iridium plug, totally cleaned carb and checked reed valves, fully charged battery but doesn't last a crack so used car battery. Bad idea it burned new starter out! Got it going and it sounded great, nice tickover, revving ok and left it running for about 5 mins then switched off. The shite has not went since! At this stage I'm about to kill it...... Checked the primary resistance on the coil and it is in spec. When u kick it the spark is very weak and sometimes non existent. You could kick it 5 or 6 times and it won't spark. This bike was always a pain to start so I don't know if it's an aerox thing or not? Can anyone let me know what other checks I need to do and even though it looks obvious I'm not sure the coil is faulty? Another thing is can the bushes be bought for the starter motor for these. Is the spark normally weak from the kickstart. The kickstart was obvisually designed for the feet of a 6 year old girl! Any help or advice will be much appreciated.
  3. joemac posted a topic in Yamaha Workshop
    Does the plastic cover on the head need to come off to allow access to the plug. I cant get anything on it other wise as the tool just hits a bar on the frame and wont allow the box spanner to go on, any help much appreciated Thanks
  4. Hi Guys The young lad came back on the bike last night and the seat wont open. The key turns and u can hear the catck sounding like its working but the seat wont move.......anyone know how to get around this or how to get at the cable, thanks in advance.
  5. Thanks
  6. Hi Guys My son has an aerox 100, I'm trying to change the plug and guessed at removing the seat/storage compartment but .........wrong. Now I dont want to unscrew everything so can any of u guys tell me which panels need to come off to change the plug please.
