psbresner
Everything posted by psbresner
  1. I have a SR125 and intend to take my test on it, I had no idea there might be issues. How crazy!! Paul.
  2. Thats great news!!! So glad for you, I know how frustrating it is. Thanks for all your help. Paul.
  3. The screw was there, its a recessed screw. Well I reset it to factory conditions but now it cuts out all of the time. Checked the air filter and that was dripping in oil, have cleaned it with petrol and left to dry out. Paul.
  4. Hi guys, Finally got it started last night after charging the battery. Not running very well thou, starts with choke and after a few seconds the revs go crazy. If I put the choke in it cuts out. I think the mixture is wrong as the spark plug is black, can't find my mixture screw thou. Just seems to be a hole where it should be. Thanks Paul.
  5. Thanks for the info. Got the battery on charge as we speak, tried a new plug and set the gap. Fuel might be the problem then, how quick does it go off?? Thanks Paul.
  6. Hi Guys, I have a 96 SR125 which was starting ok a while ago, I haven't started it for 6 months but it has been under cover. I tried starting it the other day but it wouldn't catch. Seems to turnover ok. I've since tried replacing the spark plug but that made no difference, seems to be a strong smell of fuel around the spark plug. Battery seems fine but will put on charge anyway. Not sure what I should try next. Thanks Paul.
  7. Thanks Jim, I went for a D8EA in the end, got it before your I saw your post. Bloody thing still won't start, so I don't think the plug is the problem. Paul.
  8. Hi Guys, Which spark plug should I get? I have a 96 SR125. Some places say the NGK DR8EA and some say the D8EA?? I'm confused now... Thanks Paul.
  9. I seem to be in a similar boat to you and I own the same bike. I've yet to go on my first long ride, still staying local and practising. Reading whats been said has helped loads, although I'm still very nervous about it all. Thanks Paul.
  10. I have a similar problem with my SR125, it will only start with a little throttle. Does this even when warmed up. Runs fine once started thou. Paul.
  11. Hi Guys, Had my SR125 for a couple of months now, everything seems fine apart from the clutch doesn't seem to bite until the lever is almost right out. Does anybody know is this normal or should I adjust it if possible? Thanks Paul.
  12. Thanks for all the advice guys. All sorted now thanks. The leads do seem rather short. Thanks Again, Paul.
  13. Help!!!!!!!!!!!!!!!!!
  14. Yeah I know the feeling paid £300 for my 96 Sr125 Paul.
  15. Hi Guys, Removed both side panels, easily managed to disconnect the left hand side which is below the airbox. Still can't access the right hand side thou, seems to be too much in the way. Grrrr!! Paul.
  16. Can anyone help me remove the battery from my SR125, I have a haynes manual but thats not very clear. I have tried, can disconnect 1 terminal but the other I can't get to. Help!! Thanks Paul.
  17. Thanks for the info. All sounds abit complicated to me. Paul.
  18. Hi Guys, I'm about to service my sr125 with the help of someone who knows what they are doing. I've been asked to get the parts, I'm guessing oil, oil filter etc Can anyone give me a list including part no's Many thanks Paul.
