Everything posted by get lose
newwer body for yzf 750!!!!!!!!
has anyone out there put a newer body off a r6 or r1 on a yzf750!! if so what year!
need help please!!!!!!!!!!!!!!1
got the problem taking care of!!pulled the tank up and started it wiggled some wires around and found that the pick-up coil wire where it plugs in had a loose connection!rewired and everythings good now!thanks for leading me in the right direction guys!
tried again and it cuts out everytime i rev it up in neutral 1st gear doesnt matter!!shuts off and starts right back up! could it maybe be the kickstand switch or start kill switch going bad!!!
have a 93 yzf 750 and when i acclerate hard the bike cuts off! i can downshift into neutral and start it right up!any one else out there had this problem!!!! thanks for lookin!!!!!!!!!
sluggish accleration!!!!!!!!!
finally got htis beast going it was my exup valve!!! the alignment was way off, and cables were backwards!
- main jet adjustment!!!!!
What is the main jet screw suppose to be set at on these carbs! im dumping to much gas in my cylinders! pulled old plugs, that i just put in, and they were soking wet! Right now they r set at 2 turns out! Any got a manual that can help me out! Thanks!!!!!!!!!!- checking a pickup coil!!!!!
does any one know how to check a pick up coil on a 93 yzf 750sp!- syncronizing carbs on a 750sp!!!!!!!!
do u know what the idle/air screw is suppose to be set at! on mine are set at 1.25 turn. is that about right!- synchrinizing cabs!
aonyone know what tool i need to synchrinize 39mm flatslide carbs on a yzf750 sp!- replacement forks for yzf750
im just getting started polishing my frame! got any ideals on getting it shiny like chrome!guy told me to get all different grits of sandpaper and get to sanding! once i go threw all grits of sandpaper then use a polishing compound and polishing wheel! does that sound right for polishing aluminum!- replacement forks for yzf750
its probably the seal leaking! they sell a seal kit and oil for it! and order a repair manuel and get to work. its a guy i deal with in michigan thats got a set for $150.00.- syncronizing carbs on a 750sp!!!!!!!!
what would be the cheapest way out for me. i have a 93 yamaha yzf 750sp with 39mm flatslide carbs that i was going to take out and rejet! only thing ive done is clean the carbs and put back on the bike to make sure it ran! and i dont know anything about sycronizing the carbs, but was told that there is a tool to do so! and since i clean the carb and all the jetts once it should be less difficult for me to rejet it right!- the best exhaust
whats the best sounding exhaust for a yzf750 sp out there!! thinkin of putting a hindle on!- exhaust systems
i have a 93 yzf750 sp and was wondering if i could use and aftermaket exhaust off a r6 or and r1.if so what years could i use.or should i just order a new system!- how much compression!!!!!!!!!!!!!!!!
need to now what the compression should be in my 93 yzf750sp! I can start the bike with the choke on and giving it a little gas. But once i take my hand off thr throttle it dyes out. and adjusting idle screw doesnt change either- 93 yamaha yzf750sp
finally got this thing running today. had to redo the carbs and i had a bad kill switch! still lookin 4 a frame!- 93 yamaha yzf750sp
yes it has 39mm flatside carbs.- 93 yamaha yzf750sp
trying to get this thing going! ordered a new fuel pump and clean out carbs! put it all back together and when i try starting it, it dumps gas right out of the bottom carb hoses.also need to know what frame is interchangable with this one! thanks!!!!!!!!!!!!!!! - main jet adjustment!!!!!
