get lose
  1. has anyone out there put a newer body off a r6 or r1 on a yzf750!! if so what year!
  2. got the problem taking care of!!pulled the tank up and started it wiggled some wires around and found that the pick-up coil wire where it plugs in had a loose connection!rewired and everythings good now!thanks for leading me in the right direction guys!
  3. tried again and it cuts out everytime i rev it up in neutral 1st gear doesnt matter!!shuts off and starts right back up! could it maybe be the kickstand switch or start kill switch going bad!!!
  4. have a 93 yzf 750 and when i acclerate hard the bike cuts off! i can downshift into neutral and start it right up!any one else out there had this problem!!!! thanks for lookin!!!!!!!!!
  5. finally got htis beast going it was my exup valve!!! the alignment was way off, and cables were backwards!
  6. What is the main jet screw suppose to be set at on these carbs! im dumping to much gas in my cylinders! pulled old plugs, that i just put in, and they were soking wet! Right now they r set at 2 turns out! Any got a manual that can help me out! Thanks!!!!!!!!!!
  7. does any one know how to check a pick up coil on a 93 yzf 750sp!
  8. do u know what the idle/air screw is suppose to be set at! on mine are set at 1.25 turn. is that about right!
  9. aonyone know what tool i need to synchrinize 39mm flatslide carbs on a yzf750 sp!
  10. im just getting started polishing my frame! got any ideals on getting it shiny like chrome!guy told me to get all different grits of sandpaper and get to sanding! once i go threw all grits of sandpaper then use a polishing compound and polishing wheel! does that sound right for polishing aluminum!
  11. its probably the seal leaking! they sell a seal kit and oil for it! and order a repair manuel and get to work. its a guy i deal with in michigan thats got a set for $150.00.
  12. what would be the cheapest way out for me. i have a 93 yamaha yzf 750sp with 39mm flatslide carbs that i was going to take out and rejet! only thing ive done is clean the carbs and put back on the bike to make sure it ran! and i dont know anything about sycronizing the carbs, but was told that there is a tool to do so! and since i clean the carb and all the jetts once it should be less difficult for me to rejet it right!
  13. get lose posted a topic in The Bar
    whats the best sounding exhaust for a yzf750 sp out there!! thinkin of putting a hindle on!
  14. i have a 93 yzf750 sp and was wondering if i could use and aftermaket exhaust off a r6 or and r1.if so what years could i use.or should i just order a new system!
