hamiltonblk
  1. Thanks!! The tank was empty so I have filled that now. The pump is still there and working with the throtle. To bleed it i removed a small screw on the pump caseing and twisted the throtle till oil came out ... is that right? The Neutral light isnt working and the red light isnt coming on .... how can i be sure the pump is working properlly? As for the old air filter that just disintergrated in my hands!!! Any good ones you can recomend? thanks again...
  2. Hi all! I have just bought a DT125MX 1980 model. Its for my son to drive around the lanes down here in the South West of france (great trails here). problem is i don't know much about bikes...can anyone tell me: What is the plastic tank on the right hand side for that says Motor Oil ..... yes ok it's for oil but should it be kept full and with what oil? 2 Stoke mixture what should it be and do you just pre - mix and put the fuel in the tank? What grade oil do you use for the engine, how much does it take and where is the sump plug? Gear Box again what grade of oil and where is the drain plug and hole for adding the box oil? I have also to replace the air filter what type / marque would be best for dusty trails? thanks guys
  3. Hi all! I have just bought a DT125MX 1980 model. Its for my son to drive around the lanes down here in the South West of france (great trails here). problem is i don't know much about bikes...can anyone tell me: What is the plastic tank on the right hand side for that says Motor Oil ..... yes ok it's for oil but should it be kept full and with what oil? 2 Stoke mixture what should it be and do you just pre - mix and put the fuel in the tank? What grade oil do you use for the engine, how much does it take and where is the sump plug? Gear Box again what grade of oil and where is the drain plug and hole for adding the box oil? I have also to replace the air filter what type / marque would be best for dusty trails? thanks guys
