ralph
Everything posted by ralph
  1. ralph replied to adihz's topic in Naked
    Hi, To question 1) Could be that the gear shaft to the side caseing has fured up, so take side caseing off, clean shaft, and clean hole in outer side caseing ,3) the oil you need is 10w30 ,capacity(without oil cooler) with filter change 2.5 liters,and ballance the carbs, all the best ralph,
  2. ralph replied to adihz's topic in Naked
  3. ralph replied to adihz's topic in Naked
  4. ralph replied to wil6488's topic in Naked
    hi,when trying to start bike with clutch in and in gear your fuel and oil light will come on it is saftey cut out,return to nautral all will be ok ,as for your clutch if the bike is not warm ed up this can happen some times,as it does on mine.or clutch plates have dryed out or stuck together ,so clutch to be stripped down and soaked in oil and put back in same order and re align clutch plate half curcle with clutch housing two dots,and pressure plate dot with inner clutch dot, not a big job , just check the markings. hope all this help,s ralph uk.
