Laidback
  1. I've used http://speedandsportinc.com/ and bikebandit, those are places in the US, not sure where you're located. Tony
  2. I by passed the sidestand switch and problem solved. Sidestand switch must have done bad.
  3. I have a xs400RJ '82, the brakes are okay. You can check the owner's manual for stopping distances. I just replaced the brake lines (OEM) but haven't finished my partial restore.
  4. Engine dies when put into gear. Looking at the wiring diagram there is a clutch switch, side stand switch and a relay. The bike has been sitting for about a year, could the clutch be stuck? It ran fine before that. I've adjusted the clutch cable. I've made sure the side stand switch is closed, next I will try starting the bike in gear with the clutch in - if that doesn't work. Does that indicate a problem with the clutch switch? Any info would be much appreciated.
