JimR
Supporter
Everything posted by JimR
  1. Hi Bob, let us know what goes on and what you really have !!! Regards Jim
  2. hi & you have either a broken black or yellow wire/Yellow & black wire ... cut back the loom casing around the headstock & you should find the wire. But you may also find that there is a loose connection behind the h/l cowl. Regards Jim
  3. JimR replied to JimR's topic in The Bar
    Hi, what's the little red waggon ? Regards Jim
  4. JimR replied to barwell1992's topic in Yamaha Workshop
    Hi, I would gues the factory would just not tape wires up so this will be after market ( I must admit I read the post wrong) it would be interesting to see which wire the +12v was hooked up to and why an extra fuse was fitted . but hey ho as the Tag says I know nothing !! Regards Jim
  5. JimR replied to metal hed11's topic in Classics
    are you on about screwing again !!! ? Regards Jim
  6. did you read the PM ? Regards Jim
  7. Hi When new it would take a good 10 ~ 15 secs for the oil light to come on after the engine was stopped .. if it stays on while running there are major problems there .... it should go out after a few seconds of the engine starting ! After listening to your 'sound track' I do think you need to look in the engine NOW before damage is done that will no longer be able to be fixed !!! (loss of parts that are no longer on the shelf) Regards Jim
  8. Hi Mark, Ok if the temp is high you will need to check out the pump .... the impeller in the pump (with age) tends to break up ... this can be checked by runing the bike with the rad cap removed as the revs increase you should see a 'whirlpool' at the rad neck if not the pump will need to be striped ... The mechanical seal to the rear of the pump if gone will give you 'white gearbox oil' and over full !!. As the pump is driven off the primary gear you may be well unlucky and have that seal (crankshaft) gone too which will allow the oil to be at the correct level (or below) .... TBH give us some more info ! Regards Jim
  9. Hi, if you have good compression on cyl#1 there will be no need realy to check the valves ... but where all 4 within about 1% of each other or was cyl #1 a little different ? if all was ok here you may need to look at the floats etc to ensure that carb #1 is not just (as you say) just supplying to much fuel. You can discount the ignition circut as if this was down cyl #3 would also act up ... Just an odd point does the bike have a YICS cylinder head ? Regards Jim
  10. JimR replied to alexi's topic in The Bar
    Hi Alex use [email protected] Regards Jim
  11. JimR replied to metal hed11's topic in Classics
    Hi, in the UK the answer would be yes but your bikes may be different .... look at the coils if they appear to have a plastic 'nut' where the ht lead enters you will be able to replace the lead with std HT lead ... but if you have a wasted spark coil (2 leads from one coil) these tend to be moulded in so therefore you would have to cut at the break use the little inline connector and add a new lead ... but they dont tend to work to well ! Regards Jim
  12. Hi Mark, it would be nice to know what bike you are thinking of .... In certain instances it could help Regards Jim
  13. Hi, I guess I need to PM you ... and I'll give you the answers !!! Regards Jim
  14. JimR replied to barwell1992's topic in The Bar
    Well I'm glad I put the cat amongst the pigeons as you may have spent some time in a French 'sing sing' or worse had your UK license revoked through misdemeanor in another country ! Regards Jim
  15. Great reading your post I could have some fun with it but I wont ! ( could say about riding at Cockseys Yard) but as long as the bike went sound what more do you need ! Regards Jim
  16. Hi Drewps Sounds like a major job ... last time I heard an XS400 in the 'throws of death' it cost the owner a head, cover, cam & oil pump along with other bits that were needed as the engine was pulled (this was in 1982 and cost approx £700 to put right). so perhaps if another engine can be found it could be cheaper !! unless you want to rebuild it ! but I guess your time in the US may cost more than another engine ... but I'll do it ½ price Regards Jim
  17. JimR replied to sleepyk's topic in Classics
    I guess the XS500 is in the bed & the wife in the garage !! Regards Jim
  18. Hi Bob to the forum ! but as stated those DT's are totally different animals and just tend to share the same tank badge Regards Jim
  19. JimR replied to alexi's topic in The Bar
    Hi Alex, there is small wonder the bike is running poor with oil being supllied via a mix & the oil pump it needs to run on one or the other !!! pump/tank or premix ! both will give bad performance. If the bike siezes when running only on the tank/pump it would indicate that the pump needs to be bled (small screw with a red washer) from the pump until all air is removed. If the bike has locked up/siezed you may need to replace/bore the cylinder and piston but I would guess the cylinder head will be fine. I would guess some bits have been lost in translation ! Regards Jim
  20. JimR replied to sleepyk's topic in Classics
    Your Hooked !!! soon the 500 will be poking it's head from under the duvet and saying "its your turn to make the cofee/tea"
  21. JimR replied to barwell1992's topic in Yamaha Workshop
    Hi, dont forget the wiring loom may be the same all over the world and what's pluged in will depend on which part of the world the bike was made for .. it's not to unusual to have the odd spare connector or two ! If everything works just leave them alone ! Regards Jim
  22. JimR replied to alec2507's topic in Yamaha Workshop
    Hi Alec no problem Regards Jim
  23. Hi, it will run with the battery on a beech on vacation .. it deoes not need the battery voltage to start ... the battery just suplies power to certain ancilary lights and also acts as a 'soak' to stop the AC light bulbs blowing ! So I guess it will start with or without a battery ! Regards Jim
  24. JimR replied to HotelBushranger's topic in Classics
    Hi BS carbs are no good at all you will need VM type carbs just keep with in these types and if you go away from std more time will be taken setting them up Regards Jim
  25. JimR replied to richiexj's topic in Yamaha Workshop
    Hi Richie, go back to the XJ750 carbs..... there is little chance that the smaller XJ600 carbs will ever allow the 750 to run correctly ... the progression holes within the carbs will be wrong so the bike may run weak or rich when the jets need a supplement (the problem you describe, holding back etc ..). But if you try hard you may be able to get the 750 to run well on different carbs but I guess the time factor may be a little long ! Regards Jim
