JimR
Supporter
Everything posted by JimR
  1. Hi, if the timing is set correctly I would guess the bike will run , there is the point that the bike has the timing running out & only runs on some form of accelerentent until it runs out and the spark dies thro some ignition timing falure or a compression issue. but if it's timing read my previous posts Regards Jim
  2. I guess no one is listening but hey I guess a DTI either way will do the problem . perhaps buy one between u ! Regards Jim
  3. oh ok if you can get that much for them perhaps we can split it !!! regards Jim
  4. Jawa's r cool Regards Jim
  5. Thats well poor ! my specs need replacing so I could send the older pairs to some one who needs them ! Regards Jim
  6. JimR replied to drewpy's topic in The Bar
    Hi, if you think its a bargain .... buy it and as a sweetener I'll do the postage Regards Jim
  7. JimR replied to drewpy's topic in The Bar
    Hi Jim, that part is more than the bike cost noo and it never fails unless a part attched to it failss . but hey ho some nut may snatch it up just in case their's fail Regards Jim
  8. to the forum That looks ruff Regards Jim
  9. JimR replied to Goff's topic in General
    dunno i guess someone must have the words 'copulating retard' do stick in my mind a bit but hey no worries just have a good day and if you are ever down here (Worcestershire/Herefordshire border) just pop in for a brew Regards Jim
  10. Try Haggis ! Regards Jim
  11. Hi Steve, here is the correct old peoples home http://www.trucktradex.co.uk/1/z_item.asp?...p;zTitle=Seddon Atkinson Euromover&zClickToSee=Click to view another photo&zZoomOptions=Zoom Options&firstImage=0 but to be honest I have added this as a joke !!!! btw if you get the DT I'll give you £700 ..... cash no questions asked !! Regards Jim
  12. JimR replied to drewpy's topic in The Bar
    He's on another planet ..... who would spend that money on a part that never fails !!! If it has failed I would gues it's time to get another engine/bike .... I'll give odds on it doesn't sell Regards Jim
  13. Where is this going ??? cream buns & stale cake .... the mind boggles ! Regards Jim
  14. JimR replied to wild foamy's topic in General
    Hi Steve, the answer will be simples (merekat wise) ... if you go a no load voltage check from the genny and get nowt (no load being the genny unpluged from the loom and the voltage checked at this point .... older Jawa's (not yours ? ) used to run silly voltages across the genny terminals (50+) when disconnected. If you have that it would be good to deem the genny to be ok and sherlock (through deduction) would discount the rec/reg .. which leaves the wires .... perhaps as DR Watson Regards Jim
  15. Well best borrow old git's I'm sure you can forge the signiture ! Regards Jim
  16. Hi, perhaps the wires could multi task !!!! just a thought who painted that engine with the black paint ? totaly ruined it !!! Regards Jim
  17. JimR replied to timhypo's topic in Yamaha Workshop
    Tim, I would guess just setting up the dwell, timing & carbs would put it right. The warm air coming out of the points cover does indicate problems with the cylinder head but tbh it is difficult to work out where thats comming from unless u know that for sure ! Dont forget the XS is OHC & not OHV !!! Regards Jim
  18. MOT
    JimR replied to NEwin's topic in The Bar
    Hi, What do you need to know ? Regards Jim
  19. Hi Steve just get the cheque book out & buy it !!! Regards Jim
  20. Who ? I guess I dont need to know !!! Regards Jim
  21. Just set the Dwell & insure the plug is ok Regards Jim
  22. JimR replied to wild foamy's topic in General
    Hi Steve try to 'uncomplex' the electrics if the brushes & rings are good and a good no load voltage is coming out of the genny wires (ac rather than dc) you should have 20v ish at this test. if you have that it would point to the regulator (in my day you could strip them and clean & adjust the points) but on your 'modern' bike you may have an ic type of regulator which may have gone down !!!! dependant on how the fork tubes get over here is a bit dependant on how the charging circut is checked .. I guess u have a meter ! Regards Jim
  23. JimR replied to Goff's topic in General
    Congrats Goff, I guess you wouldn't want a retard to turn up so i guess we will have to miss it but tbh I got married last sepember to Helen (I guess another retard) but if invited we may turn up Regards Jim but who wants a pair of old farts at there wedding anyway
  24. Hi, That wheel may have a Yam hub but does not hang out with the 278 part in total !!! (wheel) but u should get away with puting it in a bulto ...... but tbh the holes look well naf and serve no perpose ! Regards Jim
