eifion
Everything posted by eifion
  1. Thanks for the ideas, that'll give me another couple of things to check. It doesn't get through oil terribly and never smokes so I don't think it's piston wear, rear brake used to bind, but sorted that out when I changed the brake shoes a month or so ago.
  2. Hi all, I hope someone can shed some light on my SR125 getting less and less powerful as time goes on. It's a 1992 model with 18k miles on the clock, I've had it about 2 years and at first it used to bowl along at 60, 65mph quite happily. Then I got problems starting it, if it started it was OK, but often it wouldn't start. So I got a 2nd hand carb of ebay and put that in, sorted out the starting problems. Starts on the button, first time every time. But, it's not as quick as it used to be, and it's getting worse, up to the point where now it will just about hold 45mph in 4th gear, and if I put her up into 5th it won't pick up any more speed at all. It's getting dangerous on NSLs as cars are doing silly overtakes. I've always thought the new carb was a set a bit rich, as if I give it any choke at all it dies instantly, so I checked the main mixture screw, it was 2.5 turns out. I set it to 1.5 turns out but it's not made a difference. I closed it by another quarter turn, and it's still really gutless. What I've tried: Spark plug is clean, good spark, correct gap. Fuel flows steadily from fuel tap. Tried running it without the air filter foam element, no difference. I've changed the oil religiously every 1000 miles. Any ideas as to what is causing my SR to get slower and slower would be much appreciated. Thanks
