stoggy
Everything posted by stoggy
  1. I dont know man I lost like a pint of oil but yea the bottom screw hole. it was on the center stand though.
  2. Yea the diaphram wouldn't stay in the grove. I was having to stretch it to get it into that slot and it would pull itself out before I could get the top back on. grease didnt work. I fixed this though, a hair dryer and some stretching and now the carbs are working good. When I blow air past the top wide slot in the venturi tube, the cylinders raise up, and come down after wards. I also had to patch 1 of my floats but I think the carbs are good now. Unfortunately I took the alternator cover off and oil is dripping out, when I kick it oil pours out, another problem though. thanks.
  3. I just got a 77 xs400, it wont start. I am not much of a mechanic, but i figure i cant screw it up much worse then it already is. I decided to start with the carbs so took them apart, looks like they got sprayed with some kind of sealant to keep them from leaking, oh joy. when i took them apart I stuck my finger in them and raised the round cylinder things in the main tubes, and in 1 of them I could hear a thunk in the top. I got them apart and the diaphram isn't staying in place. When I raise the round thing the rubber at the top goes up too. So I cleaned them out real good, soaking in gas and a toothbrush/air compressor. When I went to put them back together one still seems ok, but on the other the diaphram wont stay in place so i cant really put the top back on, maybe with tape or something but that's ok. Is there anyway to repair the diaphram or do I need a new one? What could cause this problem? If i get a new one could the problem just smoke it too? I have seen carb rebuild kits on the web but they only seem to come with needles, springs and the bowl gasket. Do they sell aftermarket diaphrams, if so should i be searching for something other then diaphram? my is motocicle vocablary is very bad.
