2007 FZ1 ~36k lost 2 cylinders
i gave up and took it in...
a reply on another forum got me to check the coils all 4 primary and secondaries checked out ok.
2007 FZ1 ~36k miles lost 2 cylinders - i don't have a lot of technical knowledge. I can change my oil, i took my radiator off to get to the plugs, and i know how to put it back on. 2 Fridays ago I was going to work. I was going along the highway about 70 everything seemed fine. I got off the highway and i got caught at a light and when the light changed i went to take off my bike sounded like a V-twin. It had no power either. I was real close to work so i went ahead and rode in. That night I rode home, at first it sounded bad but a little gas and it came back, about 2k rpm. So i started to ride home, about 1 mile out it shut down again, I would get spurts of 4 cylinders but mostly seemed to be only 2. Of course it may be 3 cylinders or even 1 ... I got the radiator off to check the plugs. If facing the front of the bike the right most plug looks oil fouled. Not really bad but definitly some. The other 3 look a little on the white side. I tried pulling each of the plugs 1 by 1 and starting the bike with 1 plug against the block. Each time the empty socket made a air popping sound, but i didn't get any sparks. I was able to start it after putting it back together but it sounded really weak. Any suggestions where to look?
run for 10 minutes and it dies, looks like no juice.
no it wont spark at all, I cant get 2k rpm because it wont start. As in it wont start. To be perfectly clear it won't start, like at all. Or to compare it to something else, i have a table lamp that makes more noise then the bike does now. This is over 10 days so it has cooled down. Nothing shot out of the spark plug holes. I wasn't looking in the hole though i was looking between the point and the little finger on the spark plug. The plugs look clean. When i got it the points were way off. i will check them again. thanks though.
it wont run now. I checked the bowls and they are getting gas. Maybe its not going into the engine though. When I kick it, it turns over but doesn't even try to start. both spark plugs are brand new. I tried holding 1 plug at a time against the block and kicking, no spark. I tried holding the spark plugs away from the block and kicking, same no spark. how do i test the regulator? i saw something in the manual about a spark tester. is that another tool or? Can I make one or is it something that needs to be purchased, i have never heard of it, and the manual only mentions it.
nope no sparks
lost all spark now, i think. if i pull the spark plugs and kick it, i should see a spark across the plugs, right? I have tried with them up against the block and just in my hand, avoiding the metal parts of the plugs of course.
BUBBLING OIL OUT OF BREATHER!!!
looks good. i hope your a punisher fan, otherwise you got a big red stain on top of the gas tank. I think you should have left it the 80s color scheme and gone for the yuppie look, but that is just me. Good luck, good job getting it running!
Test
just wack open the throttle and leave the tester in your dust. Then he won't be able to follow you to watch so he won't be able to complain if you do something wrong. Goodluck, give 'em hell!
I finally got my 1978 xs400-2e to run pretty good. But now if i run it for about 10 minutes it will die, then it won't start and all the indicator lights are real dimm. So I don't think it is charging. Still waiting to borrow a battery tender so I can't try again for a bit. Just looking for suggestions before I get into it.
wont idle down
i went back and just gorilla tightened everything and it seems a lot better, thanks.
wont idle down
checked all around the airbox boots and into the inlet manifolds, didn't see any gaps. So i lit a smoke and none of the smoke seems to be getting sucked in or blown away.
wont idle down
tank didnt help. ok inlet manifolds. mine are like a round tunnels that have flanges to screw into the cylinder heads, behind these are like thin tin plates. ok i let check the airbox boots as well.
wont idle down
1978 xs400-2e, its got carbs. ok lets hope for airleak i have the gas tank off and was using a gatoraide bottle as a gas tank, and put electrical tape on the vacuum nosel on the carb boots. hopefully that is the problem.
wont idle down
just cleaned out carbs and now it runs and idles, on/off choke. but if i give it some throttle it revs up pretty normal but when I drop the throttle it takes like 10 secs for it to idle back down. any ideas?
stoggy
Joined
Last visited
