help required rebuilding a 1984 yz top end
hi my yz recently decided to die on me upon inspection the powervalve was damaged where the lever/arm connecs to it is cracked so new powervalve needed and piston and rings as these too were damaged so i need to know which way new powervalve goes in i know it comes in 2 halves just need to know which way it sits if anyone can shed some light it will be appreciated
help rebuilding 1984 yz 125
how to fit a dt 50 clutch
tried adjusting it up too so maybe it is the little ball bearing allthough i cant see it being that as i never removed the whole pushrod just the mushroom bit although thats not to say the previous owner didnt lose it as i bought it with no clutch
still no clutch any one got any ideas
what engines will fit in a dt 50
looking into changin the engine in my dt 50 as its a little tired out now so does anyone know what will fit and anyone got any engines that will fit feel free to message me with a price
- dt50 wiring help
cable is fine all connected
uprated springs were fited along with new clutch there is no pressure whatsoever when operating the clutch
clutch fitted clutch was very worn new one fitted and still no clutch same as before new one was fitted what now what else could be stopping the clutch working
cheers dude ill give it a go tomorrow night when i finish work
how do i fait a new clutch to a dt 50
recently aquired a dt 50 witrh no clutch i have now bought a new clutch and haynes manual but how the fcuk do you do a clutch on one without a full stripdown is it accesible from left side casing or right side casing if anyone can shed some light on this it will be apreciated
billandemma
Joined
Last visited
