sirwebster
  1. Small update, it's no longer a case of no spark, it's a case of an occasional spark, no pattern to it, sometimes it will spark twice then wait for a few seconds before sparking again, sometimes no spark at all, replaced the CDI, no difference. any thoughts?
  2. Hi all, my '96 TCat that i've had for about a month is refusing to start, it was playing up toward the end of a ride the other week (cutting out at low revs, had to be bump started) and was found to have a duff battery. New battery in, still won't fire, i've checked spark plugs 1 and 4 and don't seem to be getting a spark, got some on order just for the hell of it, but what else could it be? all the fuses are good. I removed a datatool S3 alarm during my problem hunting (did nothing but piss me off) and am pretty sure i did it right, cut the wires to positive, negative and ground, then cut and reconnected the red/white and blue/white wires and removed a badly soldered in resistor from a brown/white wire (checked the wiring diagram in the haynes manual first to make sure it wasn't meant to be there). nothing i've left in is there?
