steps39
Everything posted by steps39
  1. The owners manual is not that clear on how to check the dipstick can anyone help please. The manual states "refit (the dipdtick) but do not wrench" So does that mean rest the dipstick on the top of the threads i.e. do not screw it in at all or screw it down but do not tighten it and compress the seal? I have been warned that these engines must not be overfilled and near the minimum mark is preferable to slight overfilling because they blow the extra oil into the air intake. Thanks Clive
  2. OK I have found the solution pretty simple really probably why it was not posted up To reset the OIL INSP message post service: Press and hold the mode switch on the left (clutch) handle bar (blue button on my XT125X) While still holding the mode button switch the ignition on, keep holding the mode button until OFF appears in the display. All done. This SHOULD NOT under any circumstances be done unless the bike has been properly serviced !!
  3. I have the same problem as well. Tried googling around but can't find any info
