ginger0195
  1. ginger0195 replied to ginger0195's topic in The Bar
    how much do you think it costs to have a bike restricted to 33 break? this is probably blasphemy on this sight but i was thinking zxr400, unless anyone can think of a better yammy 400?
  2. ginger0195 posted a topic in The Bar
    i'm shortly to become 17 and have heard all sorts of stories as to what licenses i can get and which bikes i can ride on them. i just need a bit of clarification over the issue. I have my provisional license and have done my cbt at the moment regards adam
  3. ginger0195 replied to ginger0195's topic in Yamaha Workshop
    cheers pal
  4. ginger0195 posted a topic in Yamaha Workshop
    could anyone suggest the best type of paint for coating alloy engine casings?
  5. Next saturday im going to look at a 2002 yamaha dt 125 r. I know what sort of checks and inspections to make on the bike itself but what paper work will i need to see? This will be the first time i've considered buying a road legal bike and have no idea what to ask for. Adam
  6. if the fuel is premix then maybe the ratio of petrol to two stroke oil is wrong, that can cause alot of smoking. The ratio of two stroke oil to petrol should be stated on teh side of the two stroke oil container/bottle. Adam
  7. thanks guys i get it now Adam
  8. i have a dt100 carberetur, its in peices but your welcome to it (i changed the carb on my dt100 to a larger carb) Adam
  9. thanks for the replies, but i am more interested in why there is a need for auto advance? as in what are it advantages etc Adam
  10. ginger0195 replied to tom3218's topic in Classics
    ebay is probably your best bet, but also try pattern part websites, these parts and cheap and available quickly (although they will not be genuine yammy parts) Adam
  11. lol i agree Adam
  12. YBR
    ginger0195 replied to ShoKz's topic in General
    this may sound stupid but have you checked that the indicators were supplied with bulbs? how do i get the cookie? Adam
  13. If the connection between the throttle cable and the butterfly valve is external, then pull the throttle right open when the bike is not running and then watch it as your let off the throttle. If you see the throttle cable become slack and the valve not move then it is most probably a faulty return spring, or the valve is getting stuck somehow. I would also suggest checking that the inside of the cabereutter is smooth and free of lumps and/or scores that the valve may become stuck on. Adam
  14. ah yes the concept of a bike may be original (excluding cheap chinese rip offs) but the bike itself is not because there are hundreds of identicle copies. Adam
  15. ginger0195 replied to Ventrup's topic in The Bar
    air filters and exhausts are usually the most heavily restricting factors on 50s Adam
