YPVS TONE
  1. To be honest I don't use the Fowlers site to find the part numbers for the parts on the bike but I'll try and send you a link in a PM message to a pdf parts list for the 1983 LC2 model you may find useful.
  2. Here you go https://www.fowlersparts.co.uk/search/part/29L-14753-00
  3. Hi Garry If you click on this link it will take you to their parts section and you just type in the part number I listed in the part number box and click on search https://www.fowlersparts.co.uk/ I also have a 1983 LC2 model in original Black-Red colours which is virtually standard with standard pipes. Tony
  4. What year is the bike ? Though it sounds like you have an earlier powervalve 1983-1985 or LC2 or F1/N1 models which had the removeable baffles and had the same baffles. Just had a look on the Fowlers website and they are showing in stock at £29.98 + vat each. Part number 29L-14753-00. Tony
  5. YPVS TONE replied to mgs4's topic in Yamaha Workshop
    Screw the air screw all the way in until it is lightly seated then back out 1.5 turns out and this will give you the default setting. There is no setting for the idle/throttle stop screw as you just screw in or out until you get the correct idle speed. If you still can't get it to tickover by doing the above it may be the pilot jet is blocked and requires the carb stripping and pilot jet blowing out. Tony
  6. I know the DT125R I bought new in 1988 had a BR9ES fitted as standard and it listed a 9 as the standard plug in the owners manual. Even with running in and pottering around town I had no issues with plug fouling and starting so I left the 9 in. The NGK application book says DT125 1988-2004 BR9ES as the standard plug.
  7. Have a look at the spec on the back of the bottle and make sure it says JASO MA as this means its compatible with a bikes wet clutch. Most Halfords have a bike section so if you got it from there you should be ok. If not it sounds like you've picked up car oil.
  8. Looks like yambits have a 2.75 one but not the other two. Perhaps give them a call to see if they can get them. If not try a Yamaha dealer like Fowlers of Bristol. http://yambits.co.uk/advanced_search_result.php?keywords=XJ600S&sort=2a&page=7 Tony
  9. If you check the engine number this should be the same as the frame number on that year providing it hasn't had the engine changed. I have a 1983 350 Powervalve and that has the same amount of digits as yours so there shouldn't be a problem. Tony
  10. If you're sure the carb/jets are clear and there is a good fuel flow to the carb I think I would double check the electrics. You say you repaired some burn't wiring from the stator. Is the wiring ok now and insulated and not shorting to the exhaust or frame? Is there a kill switch on the bars? you should be able to unplug it from the main loom to eliminate this. Does the spark plug come out oiley? I Know you said you replaced it but have you got another to try incase the other one is oiled up. What is the plug cap like and is it screwed into the HT lead fully. If the coil is under the tank a good idea is to remove the tank and try starting the bike in the dark to see if you can see anything shorting out to the frame. You should have enough fuel left in the carb to try this. Tony
  11. Got mine from these chaps for the 350 http://www.allensperformance.com/fj1200.html Got them them a few years back for £14 each and Genuine Mikuni. Yamaha dealer wanted £90 for the pair .
  12. If you have to take the carbs off again it maybe worth checking the little tang on the float that stops the floats dropping too much (NOT the tang that adjusts the float height) as here : http://www.xs1100.co.uk/float.htm Had this on my 350 YPVS if left for a few weeks the carbs would flood even after renewing the float valves and seats and found the small tang needed tweaking to stop the floats dropping to far and putting the float valves out of line. Tony
  13. If it's not starting, while you have the float bowls off make sure the choke jets in the floatbowls are clear if they were as bad as you say. Try and get some carb cleaner to spray in the jets too make sure they are clear. While you have the floatbowls off check the size of the Main jets as in the Data book it says the outer carbs 1 & 4 should have a #105 main jet and the two inner carbs 2 & 3 should be #102.5 Although this shouldn't affect starting it's still worth checking incase a previous owner mixed them up.
  14. The Yamaha Data book I have say's XJ600S/N up to 1995 Pilot Screw 2 turns out. Only screw them in to a lightly seated position to find the starting point before backing them out. Tony
  15. Seem to remember on my DT125MX that had a seat strap fitted you could get away with just undoing one of the strap bolts before removing the seat.
