ElliottM
Everything posted by ElliottM
  1. ElliottM replied to Airhead's topic in General
    Thanks! I didn't notice your horn was a different model.
  2. ElliottM replied to Airhead's topic in General
    This is what the installation instructions say: this horn should be mounted so that the cylinder is vertical (with the horn facing down). There should be no more than a 15 degree variance from the vertical position. If it is not mounted per these specifications, then the horn may cease to function after a period of time. instructions found here http://www.bikerhiway.com/installinfo/Stebel/stebelhorn.pdf. If you aren't having any problems then that opens up more possibilities for where I can install the horn. Thanks.
  3. ElliottM replied to Airhead's topic in General
    I noticed you mounted the horn horizontally - how has that worked for you? The instructions say the horn must be mounted vertically, so I wondered if you have had any problems with the horn as you've mounted it. Has anyone mounted the Stebel on the V-Star 1300? I bought one for my 1300 but I haven't found a good spot to mount it. Cheers.
