yamguru
Everything posted by yamguru
  1. just because a manual refers to a brace of machines doesnt necessarily indicate parts compatibility the engines are all very similar enough to be covered by the one manual but they are all very different machines it is a case of trial and error when swapping parts over but i would have expected the wheels and major cycle parts to be easily moved over as most Yams from the period followed a similar sizing making swing arms and forks a relatively easy thing to exchange
  2. if you have removed the mushroom then the little ball can sometimes follow it out never to be found again
  3. several things to check really if you have fitted a new clutch then it will need re adjusting to work properly this is achieved by turning the screw in the left hand casing until it takes up the play and then backing it off a 1/4 before locking it with the 10mm nut take any adjustment out of te cable before doing this ie give the cable more slack if this fails then you have maybe lost the little ball bearing that sits between the pushrod and the mushroom at the pressure plate end
  4. yamguru replied to Smitty's topic in The Bar
    providing it aint cold you cant beat those stretchy over suits the racers wear you keep all the feel, control and stay mega dry look cool too
  5. PM me with yer email addy and ill send a full size scan
  6. the early XJ yam has always had a gasket between the down pipes and the collector box
  7. on the SRX if the float has been leaking it will fill the crankcases with petrol hence the oily petrol drain th engine oil and refill with fresh stuff and sort the carb out
  8. yamguru replied to Splinter's topic in The Bar
    if you get stuck the lads at Tamworth Yamaha are pretty good
  9. the Japanese were gearing up for unleaded as far back as 73 so most bikes from that point can run the fuel there are a few exceptions but theses are mainly sports bikes RC30, CB1100R and that speed demon the DT50MX!!!! if you have any doubts i have all the records and spec on file
  10. yamguru posted a topic in Classics
    i am on the look out for a tidy XS750 to photograph for a book UK based ideally midlands or close by
  11. every yam since 1982 has been designed to run on unleaded with many able to do this well before that point there are some exceptions but unless you have a race bike or a DT50MX i wouldnt worry about it
  12. ill email jpegs if thats ok?
  13. yamguru replied to Rowland's topic in Classics
    dont forget Moto Ward and Granby's they are both usually pretty good
  14. there is a similar manual to the kawasaki one called Yamaha special tools and service manual printed @ 76 time i have a copy but i wouldnt say it actually tells you how to build cranks anymore than the Kwak book does i can copy the relevant pages for you if you wish i know CMM magazine in teh UK are doing something soon on the subject but there is no substitute for getting stuck in im afraid
